Results 1 to 10 of 11
Thread: hot knee
    Feb 2015
    gold coast qld
    hot knee
    hey guys sorry for all the posts lately as you have probably gathered im a new d2 owner
    ive got another question regarding the center console
    are they meant to get really hot?
    the passenger side is cool but the drivers side is piping hot and a little concerning
    its weird because to start with i thought it may have just been the climate control blowing hot air out at my feet but its not, the panel is extremely hot but the air coming out is super cold...
    May 2003
    On The Road
    wow,, your knee touches the tunnel?
    where's your left foot?
    should be on the foot rest,,
    CaptainJack Guest
    you must be a shorty pedro
    For those of us who are a bit taller and have long legs, we've go no chance of using the left footrest unless you want to make a large dent in the dashboard. I have to slide my left foot next to the brake pedal, and my leg does lean against the center console. That's why I'm about to do the seat mod so i can slide it back a couple of inches.
    Back to the original thread - not sure what engine your running, but ive got the V8 petrol - no heat coming through the center console on mine at all. Sounds like you have an issue there.
    May 2003
    On The Road
    Aye Cap'n!
    back to the OP's Q',,
    bit confusing with mate taking about his knee, then the AC outlet near the foot rest,
    My navigator says the tunnel wall on her side is uncomfortable---
    Avoca Beach
    You have a transmission just under there which is running at 80C and possibly 100C.
    Hot to a human is about 45C.
    My Hot water system is set at the minimum and that is 45C and the water is too hot to use unmixed with cold.
    So its perfectly normal for the console to feel hot after a while when the heat soak has a chance to get through. the exhaust is under the passenger side also.
    Regards Philip A
    Bairnsdale enjoying the rural view no rooftops to see here
    Regards Philip A
    or both sides on a v8
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    darwin
    Just make sure that your heater is not "leaking"hot air out the outlet that pedro mentioned they have a habit of that
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Feb 2015
    gold coast qld
    Yeah im thinking im going to have to rip out my dash and check it out. Its definitely not meant to be this hot im worried the plastics will start melting soon. And its not after long drives its only after 10mins max driving so there is definitely somthing wrong. On another note is there a aftermarket transmission cooler I can fit to the auto that most people on here would recommend?
    May 2003
    On The Road
    heres a good read, and what I fitted
    http://www.aulro.com/afvb/discovery-...a-cooling.html
    Feb 2015
    gold coast qld
    Ok I think I have narrowed this down quite a bit.
    I took it for a run up the highway from the goldcoast to beenleigh and back without the climate control on and it didnt heat up at all
