Results 1 to 10 of 14
Thread: Headlight removal/replacement
    Feb 2010
    Townsville, QLD
    Hey guys
    Have done a search here, Google, YouTube and the likes, even RAVE, with no luck!
    I have acquired a set of P38 update headlights which Id like to fit up but I'm unsure completely on how to remove the old lights from the cradle!
    From a glance, it appears like its a matter of winding the adjusters right out, then it should just fall out, just wanted to hear if that's correct before I go ripping mine out!
    Keithy
    Douglas Park, NSW
    The workshop manual appears to indicate that the headlight/cradle assy is one unit.
    They fit onto 3 plastic balls - the socket side is on the headlight. I've found it's best to leave the headlight/cradle assy in the car as there's quite a bit of force needed to 'pop' the headlight off the balls & leaving them in the car enables a bit of leverage to be used. Lever as close as you can get to the joint otherwise you risk breaking the socket off the headlight.
    It might be best to give them a spray with some lubricant beforehand & see if that helps with releasing them - I'll be doing that next time as I had to reattach one socket to a headlight.
    I did it when I had a cracked headlight but I don't recall any difficulty.
    Feb 2010
    Townsville, QLD
    Thanks guys! Should I wind the adjusters out, or leave them and just try and pry from the (3 I assume?) sockets?
    Keithy
    I don't remember. Too long ago.
    Douglas Park, NSW
    I didn't touch the adjustment side of things at all
    In fact, I changed from LHD lights to RHD & didn't need to touch any part of the adjustment.
    Feb 2010
    Townsville, QLD
    Ok cheers.
    I'll have a go at prying the light out as is (and I'll be gentle - I hope!)
    Feb 2010
    Townsville, QLD
    Update:
    Job done! You were correct in saying that you can "pop" the light off the sockets. I used a large screwdriver for leverage, and gave the lights a tug in the general region.
    Next question!
    The rh light has condensation, how would I go about getting it dry?
    Blow warm air in through the lamp opening? It will exhaust through the parking light globe hole. See this pic from Stefan Lindgren's website:
    Feb 2010
    Townsville, QLD
    I took your suggestion on board Ron, had a 4hr drive today so I removed my park light bulb from the holder and drove the whole way with headlights on, allowing any heat (condensation) to escape through the park light hole. I don't have any condensation in the light any more!
    Keithy
