Results 1 to 10 of 11
Thread: Wire in brake
    Apr 2014
    Australia
    Wire in brake
    Okay all ...i know its something simple .. but ... why is there a wire jammed into my front brake pad of my Perentie .. i bought it a week ago and decided to lie underneath it and saw this ... the cable is tied onto the brake pipe so its meant to go somewhere ... the other side doesn't have the wire ......
    Hay Point
    Wear indicator wire.
    Cheers......Brian
    1985 110 V8 County
    Apr 2014
    Australia
    Why is it stuck in the pad ??? And there isnt one on the other side 😨
    Avoca Beach
    It is assumed that both RF and LF wear at the same rate.
    The wire is in the pad so that when the pad wears down to the wire depth, it grounds on the disc and Voila! a light comes on on the dash.
    There should be one at the back also.
    I didn't know they had them . I thought only such poshness as RRCs had them. Ya learn something every day.
    Regards Philip A
    the brake wear indicator works by completeing the circuit to the idiot light to the electrical earth of the vhciels, as the pad wears away the wire gets exposed and putting your foot on the brake pushes it against the rotor making the light come on
    if it comes on and its not from a short somewhere else it means the operator or the mechanic, frequently both are idiots.
    Apr 2014
    Australia
    Bloody hell ... i did not think a perentie was that clever 😅😅
    Quote Originally Posted by Themadmob View Post
    Oh theres quite a fair bit of clever buried away in there if you know wht your looking for...
    little things that belie years of experience in getting something to go from point A to B in the most arduous of conditions with the simplest of equipment.
    Apr 2014
    Australia
    Brilliant .. what else can i find thats different 😊
    Davehoos Guest
    original pad set had 4 contacts. one each. the wires tired together. The original pads without wire from UK thrown in the bin to increase content.
    the parts book showed a wire that forked to each side for 2 inner pads. The story I was told that in service the left side wore out first, depending on who you talked to most favoured the inside pad.
    so the contact was fitted for army use to reduce service checking-then the extra wires deleted to reduce cost.
    I noticed on my 94 disco that all 4 are connected.
    Apr 2014
    Australia
    Interesting ... The wire is on the left front .... But ... Surely it's not just jammed in between the pad and rotor ??????
