Results 1 to 10 of 17
Thread: Intercooler upgrade, oil on radiator, any ideas
    Mar 2012
    Adelaide SA
    Hi All,
    In the process of upgrading to a 2A intercooler I have noticed what i think is oil on the radiator??
    There is no oil on the old intercooler.
    Seems to blow off with compressed air though.
    My thoughts is the the fan hub is about the same height, could be leaking?
    Any idea guys, anyone seen it before?
    Mar 2012
    Adelaide SA
    Got it in thanks to the instructions here..
    http://www.discovery2.co.uk/intercooler.html
    I bought some silicone hose that look like terrafirma by the model number on the bag. Only 2 of the three fit. The LH front one has no where near the bend needed to clear the ACE pump.
    Bugger now I find out there is a specific ACE hose kit..
    Any one want to swap a black non ACE hose for an ACE hose??
    Dec 2009
    Baldivis WA
    Quote Originally Posted by DiscoKym View Post
    It may actually be the hose coming from the turbo which is incorrect.
    A Discovery Td5 hose has an angle under 45*, but a Defender Td5 hose is over 90*.
    If so you should be able to cut the 90* hose to the correct angle.
    Discovery Td5 kit
    Defender Td5 kit
    Mar 2012
    Adelaide SA
    One of the kits shows both ACE and non ACE pipes.
    Ace pipe is second from left..
    Apr 2010
    South Melbourne
    Have you tried rotating the steel interconnecting pipe? This should clear the ACE pump.
    Jan 2014
    Perth Western Australia
    Hi All,
    Its dirt that has been sucked into the radiator fins by the viscous fan, if it has collected on the opposite side to the engine fan (so between intercooler and radiator?). Its stuck there because at some point, the intercooler might have the slightest leak, the radiator might have a slight leak (on both accounts the leak would be dampness) or the dirt was damp when it was sucked there, or maybe too much crc spray on the bonnet latch was used.
    A bit of a exterior clean of cooling fins now and then is a good thing. The same sort of crud can build up on the fins of the centre viscous coupling fan, which also requires a clean now and then.
    Daz
    Mar 2012
    Adelaide SA
    Quote Originally Posted by simonmelb View Post
    No I didn't because there is a dent in the tube to clear the ACE pump so it only goes in one way..
    Feb 2010
    On the Murray at Echuca
    Unfortunate colour
    Its amazing what they can do with snot.
    North Central Victoria
    Quote Originally Posted by kelvo View Post
    Discovery Td5 kit
    Defender Td5 kit
    You sure they aren't the same images?
    Dec 2009
    Baldivis WA
    Quote Originally Posted by gusthedog View Post
    Er yeah, don't know what happen there It was right
    Discovery Td5
    Defender Td5
