Results 1 to 8 of 8
Thread: Charging via tow plugs-Any auto elecs here?
    From the English D4 site
    Tow electrics charger adapter - CTEK/Accumate/Optimate etc - DISCO3.CO.UK - Shop
    Do the Aussie spec D4s have plugs that will do this. I am electrically ignorant!
    2003 D2a Auto TD5 good Landy gone
    2015 D4 probably the most amazing yet, why get a RR?
    Aug 2010
    Yep, I made one using instructions from another post in the Disco3.co.uk sites.
    Works great.
    Up to you which way you want to go, build yourself or buy premade.
    2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
    Oct 2013
    Old Toongabbie, Sydney NSW
    I bought one of the connections from that site and use it via the trailer plug to keep the battery charged as I do a lot of very short trips. Use it about once a month as a maintenance routine. Works fine.
    Martin
    Quote Originally Posted by letherm View Post
    +1.
    Martin
    Thanks, and pardon my electrical ignorance, which exact model for Aussie?
    LRD414's Avatar
    Oct 2014
    7 pin 12S is the one you want. That's the white trailer plug.
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
    Queensland
    Hi Nicky, just e-mail Martin on the Disco3 site and he will know it's the WHITE plug version you are after.
    JamesH Guest
    I got one too for monthly maintenance. Had a bit of a scare camping when my DBS isolated on the first night of a camping trip after a four hour drive. I must have had very low voltage when I set off. Regular top ups are necessary, even with a DBS and the ctek chargers work best when hooked up for a long time, charging through the trailer plug allows you to lock the car, you even lock the charger in the car too, rather than bonnet up and that makes you feel beeper leaving the charger on for a longer time.
    Oct 2013
    Quote Originally Posted by Nicky View Post
    Make sure that you select the correct battery charger connection. If you have something different he will make one up for you to suit for an added cost. I had an old charger with alligator clips and e-mailed him and he was very helpful. In the end I bought a modern CTEK 5 amp charger so the standard connection was suitable.
