Results 1 to 8 of 8
Thread: Bigger tyres legally
    Mar 2010
    Hi all
    Last I checked, VSB 14 limits us to a tyre size of 31". I did hear that mid last year some sort of review on cars with ESC was being done, and after that, a review of suspension and tyre sizes was happening. Since then, the info on these supposed reviews has dried up with no new info. Anyone heard of any updates?
    WA is analy retentive with VSB 14, and won't consider going outside the regs, has anyone managed to get a Disco legal with bigger tyres than 31"?
    Those in other states, especially those who have adopted the NCOP VSB 14, does your state give exceptions, has anyone legally fitted tyres bigger than 31" recently.....please not under old rules, only NCOP.
    Cheers all
    Kev
    Kev
    2005 TDV6HSE D3
    2006 V8HSE D3
    99 TD5 D2 (Gone)
    97 RR Autobiography original (Gone)
    Ellendale Tasmania.
    It's 7% of your standard size for the model, so D2s were 29" add 7% = 31.03, you can go higher, but you'll need it to be engineered, that's for NSW anyway.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Dec 2009
    Tyrendarra Vic (South West Vic )
    Pretty sure your allowed a total of 3" lift . In any combination. But a maximum of 2" larger in tyres + 1" lift springs . Anything more requires an engineers certificate.
    Apr 2010
    South Melbourne
    Tallest is 790mm, so a 245 75 16 is sensible and popular.
    Tallest in this size I can find is one of these at 781mm. [ame]http://toyotires.com.au/images/tyres/factsheet/pdf/m55.pdf[/ame]
    Simon
    Nov 2008
    Roleystone, Perth
    Makes a mokery of the hundreds, (well maybe tens) of D2's running around with 265/75/16's. Meh.
    Nick
    Feb 2011
    Hobart, Tasmania, Australia
    Quote Originally Posted by TD50WA View Post
    Kev, your question is pointless. NCOP VSB 14, as you well know, does not allow a D2 with standard diffs to run a tyre larger than 31" legally - engineered or not. It allows up to a 150mm lift which can be made up of 75mm suspension lift, 50mm body lift and 25mm tyre lift (which is a 50mm larger tyre).
    There is one way around, the fitment of Defender diffs, would make the Defender 31" tyres the standard tyres and allow you to go up to 33" tyres. This would obviously be expensive and complicated.
    NSW seems to use NCOP as the basis for it's rules but with a relaxed application and has a few State rules that replace parts including tyres - but this doesn't answer you question as it's therefore not NCOP VSB 14 being applied.
    Mar 2010
    Quote Originally Posted by twr7cx View Post
    Cheers, but I don't see that it's pointless as I'm simply asking what other states do, and if anyone has any updates on the supposed review if the tyres and suspension section of vsb14.
    WA will not even allow the 75mm of combined lift that other states enjoy without engineering as this is a side agreement, not part of the vsb14.
    I have heard of the diff swap and even that doesn't wash over here because the tyre size is calculated on the tyre placard of the original vehicle.
    It appears that the supposed National Code Of Practice is not exactly the same every where after all.....WA used to be good before as we had reasonable scope with engineering, now we can't do bugger all by comparison.
    Kev
    2005 TDV6HSE D3
    2006 V8HSE D3
    99 TD5 D2 (Gone)
    Jun 2011
    Victoria - Pakenham
    Quote Originally Posted by 33chinacars View Post
    This is close to Vic rules. 75mm (3in). Max of 1 (25mm) inch tire lift (which is a 2in larger tire) and 2in (50mm) max suspension lift.
    Body lifts are not permitted as it is not considered a suspension modification, it is a body or chassis modification.
    Be careful as the rules differ from state to state. I'm pretty sure Vic has the most legal amount of lift at 75mm or 3in as per the above combination and has a amendment to VSB14 specific to VIC.
