Results 1 to 10 of 24
Thread: Gearbox issues!
    Mar 2014
    Macedon, Vic 3440 Australia
    Gearbox issues!
    G'day All,
    I'm looking for advice on Gearbox's. My 4 Speed Parentie is difficult to get out 2nd, into 3rd and after a professional inspection inside the box, I've been told she needs an overhaul .. cost approximately $3-3500 (excluding removal and installation). I've sourced a used Parentie 5 speed, for $2,500 (with a 1 or 3 month warranty), but am unsure of;
    a) Whether i'd be better off overhauling my 4 speed?
    b) Whether the engine will labour with a 5 speed box?
    c) Whether it will bolt straight in with minimal hassle?
    d) Whether the tail shaft length needs adjusting?
    e) Any other unknown issues?
    I'd appreciate any input from some knowledgable members out there please.
    What do you think?
    Deaf Ender.
    Jan 2009
    Seymour, Victoria.
    Hi,
    I'm no expert by a long shot however I have spoken at length to the RAEME boys at work about our Landrovers,
    I have been told that the first trails vehicles where fitted with 5speed transmissions and performed well only being discounted because defence wanted to limit top speed to 80kmh. Apparently due to the safety concerns with towing the 1/4 ton trailer. And,
    The box is capable of being converted to a 5 speed as defence simply optioned the Range Rover box minus 5th as this was the only box available that could handle the 3.9 litres torque at the time. Therefore one would assume that the tail shaft should be ok.
    Have you checked prices on the Ashcroft Transmissions website? I'm sure you could get one delivered much cheaper.
    Aug 2010
    Sunbury, VIC
    The LT95 4 speed you have is about the strongest box LR ever used, and is much stronger than the 5 speed. The torque pulses from the 4BD1 engine give boxes a hard time. Shop around for a decent second hand box. The Perentie boxes have the roller taper bearing conversion in the transfer case, and is worth keeping - they are an expensive bit of kit.
    Parts for a rebuild are around $1000 so the price you've been quoted seems ok I suppose. Are you handy with the spanners? You could at least remove the box yourself and save some dollars. Probably not a beginners box to try and rebuild yourself.
    We need Bearman to chime in now, not much he doesn't know about these units.
    Mar 2014
    Worth keeping 4 spd
    Quote Originally Posted by bacicat View Post
    Thanks bacicat, I take it you think I should get her overhauled. The quoted rebuild price included the transfer case. At least then I'll know exactly what I've got.
    Appreciated, Deaf Ender.
    Mar 2014
    Good info.
    Quote Originally Posted by landy View Post
    Hi,
    Hi Landy, I'll check Ashcroft thanks mate. Thanks for the good oil.
    Deaf Ender.
    The perentie Never had a 5 speed
    if you have a 5 speed "perentie" box what you have is an r380 from one of the td5 110's that were bought into guiseas a perentie late in the piece.
    no, its not going to bolt straight onto or into your 4bd1 perentie.
    parts for a mainbox overhaul are between $500 and $2500 depending on what can be salvaged
    parts for the Tcase side go about the same
    $3-4k is an average ball park.
    a quality workshop working effeciently and quickly generally wont let you get away with paying less than $1.5K for a rebuild alone as there are some things that while you technically can reuse experience and best practice says you dont.
    Mar 2014
    Gearbox issues
    Thanks blknight, I'll determine whether it's an R380. Is it possible to use the R380 on the 4bd1 at all, perhaps with minor modification?
    Deaf Ender
    Depends on your definition of minor modification
    you might need to have an adaptor plate /flywheel housing made up and you might need to change the friction plate
    an lt85 with an lt230 should be just about a drop in fit but you'd have to get the diesel version. IT wont last as long as the lt95 though
    Last edited by Blknight.aus; 15th April 2015 at 07:57 AM. Reason: bad text insert when I edited before posting
    Mar 2014
    you might need to have an adaptor plate /flywheel housing and you might need to change the friction plate made up. I think the input shaft lengths are different.
    Sounds like I should stick with the Lt95 then.
    Much appreciated,
    Deaf Ender.
    Feb 2013
    Sunshine Coast
    Quote Originally Posted by Deaf Ender View Post
    Deaf Ender
    There are a number of 4BD1(T)s out there with R380s behind them, of which I've driven a couple and own one. If you decide to go that route, you'll need a friction plate to suit the fine spline R380 input shaft and a bellhousing modified to accept the gearbox (and the R380 itself, LT230, gearbox and transfer case mounts to suit and a Defender front propshaft). Parts for the conversion are available through KLR Automotive.
    Modified LT95 Bellhousing/R380/LT230 on the left - LT95 on the right, because everyone likes pictures.
