Page 1 of 14 12311 ... LastLast
Results 1 to 10 of 132
Thread: Series 2a restoration
    Apr 2015
    Cairns
    I have just purchased a Series 2a Land Rover - I have called him "Wilf". It was sitting in a paddock near Bundaberg Queensland for 12 years without the roof on. It was build in 1971. The chassis number is 25334973G and the engine number 25170084F. It is ex army. It was purchased from the army Febuary 1990.
    It seems to be in good condition. The engine runs well with no smoke. The clutch is not working and you cannot depress the pedal. the chassis looks in very good condition - no rust or rot that I can see. The previous owner said he had covered it in fish oil before putting it in the paddock.
    I am looking to restore Wilf to his former glory. I have never done a car restoration before. I don't really know where to start - I guess I will strip it right back to the chassis and rebuild it replacing any parts that are needed. I guess there will be some welding needed and some panel beating. I am expecting a lot of work. I have ordered a restoration manual and hopefully that will give me some ideas of where to start. Any advice would be gratefully received.
    I will use this tread to update on my progress.
    Apr 2015
    Cairns
    Wilf - front
    Picture of the front
    Apr 2015
    Cairns
    Wilf - inside
    Inside Wilf
    Apr 2015
    Cairns
    Wilf from behind
    The back of Wilf
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    Bit of work to do, but doesn't look too bad. One thing you will need to decide early on is what sort of restoration you intend - bring it back to 'new', as delivered to the army, or to a good working vehicle, or something else.
    A good start will be to get a copy of the factory workshop and parts manuals, most easily on CD from the AULRO shop (see header of this page), and sit down and read as much as you can of the Series 2/2a (and also Series 3 and some other) forums here as you can - this, particularly the stories of others' restorations, will give you a good idea of where you need to go and what the pitfalls are.
    One point to note is that the restoration manual covers primarily the home market Landrovers. The Australian ones, and especially the Army ones, differ from these in many details, one early point you need to know is the location of the chassis number, which is on the LH rear back spring hanger on Australian assembled Series 2A.
    All the best, and keep us informed of your progress.
    Apr 2015
    Cairns
    Thanks John
    Thanks John
    I would like to get it back to original condition - I would like to get it back on the road - but not as a "working" wagon.
    The manuals part one and two came with the car so I have those. Thanks for the advice about the restoration guide. I have the chais number from old documents that came with the wagon - I will look for the number - why is this so important to find?
    I have been looking at accounts of other restorations.
    Many thanks for your advice.
    JDNSW's Avatar
    Quote Originally Posted by Chinookflyer View Post
    .......... I have the chais number from old documents that came with the wagon - I will look for the number - why is this so important to find?
    Assuming you intend the vehicle to be registered, or, at some time intend to sell it, the chassis number, stamped into the chassis is required for legal proof of identity. This requirement has been getting tighter over the years, and can only be expected to get even tighter, as legislation to prevent "rebirthing" of stolen vehicles gets ever more strictly enforced. Of course, rebirthing of Series Landrovers is not a serious issue in Australia (it is in the UK!), but the same rules apply to all cars.
    But actually, I simply meant the position of the chassis number as an example of an Australian assembled difference rather than as an important difference.
    Apr 2015
    Cairns
    Chasis number
    The Chasis number is 25334973G I have got this from the documentation that came from the army when it was sold at auction. I will check that this matches the number on the chais - I think it will.
    Thanks for the advice John
    All the best Scott
    Dec 2009
    Queensland (though occasionally elsewhere)
    Good luck with this. I'm sure we're all looking forward to seeing Wilf undergo his rebirth.
    JDNSW's Avatar
    All the best Scott
    Should also be on the Landrover plate in front of the gear lever and on the 'Census' plate usually on the LH side of the seat box. But neither of these carry any legal weight as they are easily swapped between vehicles and in any case are on the body not the chassis.
