Results 1 to 10 of 22
Thread: Motor Options????
    May 2012
    Birdwood, SA
    Motor Options????
    Hi All.....
    Just after a few suggestions as to what people think is the best option....... My 2000 4.6 Thor motor has apparently decided to crack a sleeve in #7 pot.
    What are peoples thoughts on.....
    1) Replacement with a low k's motor..... hopefully not with the same issue
    2) Rebuild current motor
    3) Silver Seal it and hope for the best... I know its still only a temp fix
    4) Any other suggestions welcomed
    Kel
    Feb 2012
    Carnegie
    Has the current motor overheated? A hardness test on the block would be recommended as this may discount option 2. Option 1 will definately be the cheapest option, but does have a fair degree of risk associated with it.
    Feb 2010
    Townsville, QLD
    Thanks for posting :-) I'm glad you did!
    Two options if it were me.
    1) Rebuild. Add a few extras such as top hat liners, head work, torquer camshaft.
    2) LS1/2. Tuning options opened right up just by slotting it in.
    What are your plans with the P38? Lifetime or long-term vehicle, or will you sell it and move on in a few years?
    Short term, a good second hand engine will save you money.
    Long term you will appreciate the rebuild.
    Lifetime you will appreciate an LS1/2.
    Keithy
    Jul 2014
    Kel, I would think it depends on other factors as well...such as.
    How is the condition of the rest,
    How long do you plan keeping it....etc
    If it were mine I'd rebuild if possible.
    2000 4.6 HSE Alveston red
    2007 307 xse peugeot
    1974 xj6l jaguar
    May 2012
    Birdwood, SA
    Thanks for the comments so far.......
    I would like to keep the car and get it set up for a little more touring and off road work. The rest of the car is in great nick.... a few Rangie issues, but nothing else major.
    Yes... unfortunately the motor has overheated
    Keithy P38...... I like the idea of the LS1/2 option, but havent found much on this conversion so know very little about it. I was under the impression that the electronics compatibility side of it all is a "no go"
    I also had in mind a lexus V8 conversion, but again wasnt a $$$ viable option
    I would like to know more on the LS1/2 option
    Hope this extra info helps
    Kel
    99.87 MB
    I would install a rebuilt replacement 4.6 with top hat liners or have that engine rebuilt with top hat liners.
    Slunnie
    Feb 2010
    Townsville, QLD
    I was doing some research on LS engine swaps into P38's a month or two ago to gather intel for my future plans. Thus far (in Australia) I'm aware of 3 that have been converted, possibly 4. All of which are GEMS P38's.
    On the international forums there are a few too, same again, GEMS converted to LS.
    The consensus from what I read was that "tricking" the Motronics ECU to believe it is still participating in the operation of a P38 (for BECM's sake) is harder than getting a dinner date with the Queen.
    There is one lad who I'm a bit hazy on the details, has an LSX (iron block) in his but am unsure if GEMS or Thor.
    More research needed!
    It can't be that hard right?
    Keithy
    The "lad" who used the iron block is "Leftlanetruckin" on the Rangerovers.net forum. He's a very resourceful chap with seemingly endless resources to get stuff sourced at a reasonable price and machined to his satisfaction ... he had to get a bespoke adapter plate made for the transmission, a bespoke timing wheel for the CKPS etc ...has been a very interesting, albeit complicated path.
    Another alternative is a 2.7TDV6 as per http://www.bodylogicuk.com/index.php/11/327170/ The cost however is likely more than the current worth of the vehicle. Plus lots of mucking around.
    I would probably heed Slunnie's advice and go with a top-hat refurb... stick with minimum complexity
    Douglas Park, NSW
    Quote Originally Posted by Kel Jean View Post
    There might be some info in the thread that goes with this post:
    http://www.aulro.com/afvb/p38a-range...ml#post1827902
    Feb 2010
    Townsville, QLD
    So what I sifted from that thread was that Lee from Labtronx has set up BCM's on GEMS P38's for LS engines, but sadly the Motronics is harder due to armoured prison guards.
    Stupid question here...
    Can a Motronics P38 be equipped with GEMS gear for the sole purpose of an LS conversion?
    EDIT: I wish people who do these one-off conversions would document it on forums or websites to make it easier for others to do in future!
    Keithy
