Thread: Auto computer move Disco 2
    Jun 2011
    Victoria - Pakenham
    Today I managed to move the Auto ECU from under the front passenger seat to more or less the inside back wall of the centre console. Can't tell it is there and no space has been lost. Whoever told me it could be done, thank you. Not going to be scared of river crossings now.
    Kallangur, Brisbane
    Well done, a good idea. How about some photos...
    + 2016 D4 TDV6
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    A plastic bag and some zip ties would have accomplished the same
    What happens when the water is deeper and reaches the centre console
    Jun 2011
    Victoria - Pakenham
    Quote Originally Posted by Milton477 View Post
    I knew someone would ask. But didn't take any. I wasn't confident I would work. It only just fits and was tricky to get back together. If I need to pull it to bits again I'll take some pictures.
    Basically all I did was make a 90 degree bracket that screws into the air ducting pipe. The vertical part comes up between the back of the centre console bucket and the back of the console. I drilled 4 holes in the bracket so I could mount the ecu to it with the same plastic screws the original bracket used. I cut a slit in the loom insulation tape to keep the orange wires going to the plug under the seat. With the orange wire going where they needed I taped up the loom again. The ecu is mounted with the plug coming up from the bottom, as it is now mounted vertically. The plug rests on the ash tray. Pretty easy with the right tools.
    Jun 2011
    Victoria - Pakenham
    You're a funny man. A plastic bag wouldn't allow me to mount the ecu again unless I put holes in the bag where the screws go. Kind of defeating the purpose. Beside isolations is better than insulation. If by some chance the water gets higher than the console, I think I'll have bigger problems 😥
    Bacchus Marsh Vic.
    http://www.aulro.com/afvb/discovery-...auto-comp.html
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Jun 2011
    Victoria - Pakenham
    My install is different to this. Possibly more simple. It also places the ecu higher than the srs ecu.
