Results 1 to 10 of 19
Thread: faulty fuel gauge
    Mar 2015
    Portland NSW
    faulty fuel gauge
    Sorry if this has already been covered, my fuel gauge read full but it is not.
    I have about a 1/4 tank of fuel I puled the sender unit up but not out as i could not figure out how to get it out. as it came up it read empty so i played with the float but even lifting it up a tiny bit it read full again. any help would be appreciated.
    JDNSW's Avatar
    It would help if we knew which model Landrover you have. Guessing that it is a Series 3, the most likely problem is faulty earthing on the voltage stabiliser, located on the back of the speedo. If it is a Perentie, the most likely problem is that the gauge is not properly earthed.
    Hope this helps,
    Mar 2015
    Portland NSW
    Hope this helps,
    It is a Perentie i have tested all connections for continuity to the chassis and all seemed fine to me but I am not a auto leco may have to test again.
    Mar 2015
    Portland NSW
    just found my gauge lights also do not work could this be related
    JDNSW's Avatar
    That strongly suggests that your problem is the earth to the instruments (does switching the instrument lights on and off change the reading? Remembering to allow for the slow response of the gauge). I predict your engine temperature gauge is misbehaving as well.
    In my similar vintage civilian 110 the problem was that all the earth leads for the gauges end in tags stacked under one of the nuts securing the speedo, with another tag on a wire to earth. This nut was loose, and the fix was to tighten it, clamping the tags together again.
    Hope this helps,
    Mar 2015
    Portland NSW
    I will check when missus gets home as 3 kids and my head in a dashboard don't work well my temp gauge works fine so that's why I am puzzeld
    Mar 2015
    Portland NSW
    Gauge lights fixed was faulty dimmer so bypassed with a spare terminal I found
    Feb 2014
    Sounds like the same issue I had with mine.
    The sender unit had stopped working and only registered 1/4 tank or full.
    The sender is available from LR but make sure you are sitting down when they tell you the price.
    I am thinking about having the old one rebuilt.
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Mar 2015
    Portland NSW
    Quote Originally Posted by Phil B View Post
    Phil did you still have the Part number on Hand. may try the usual English suppliers Fingers crossed.
    Feb 2014
    It is an ADF specific part AYG9825 (VDO I think) and it is not available in the UK.
    If you find one for a reasonable price please let me know and we can share freight.
    Regards,
    Phil B
    Custodian of:
    1978 S3 swb canvas
