Results 1 to 10 of 15
Thread: 03 disco lighting upgrade
    nutgrass Guest
    anyone had any experience with new style lights and upgrading them at all??
    Just wondering how they handle heat output?
    Who might have loom/globe kits?
    Nutgrass
    Warburton, Victoria
    Pirahna have wireing and light upgrade kits.
    Why not make your own??
    Steve
    Queensland
    Hi nutgrass, what is it that you actually want to do.
    I’m in the process of getting a headlight wiring up grade project ready to post.
    If you have any ideas or more importantly any questions and I’ll see what I can do to address them in the project.
    nutgrass Guest
    Thanks Guys
    Certainly could make my own, not a problem, but a little concerned about the ability of the lights/surrounds to handle the additional heat of higher wattage.
    Basically just doing the deal on the disco now (couldn't really get a decent defender here) and haven't seen the lights closeup, just concerned that they might be a bit plasticy maybe.
    Need to get low beam wattage/spread up as we do a lot of country miles.
    99.87 MB
    If it helps at all, Ive been running 90/100's in my D2 for about 3 years now without drama. I'd assume (perhaps incorrectly) that the D2a headlights are a similar material and the looms are basically the same.
    Slunnie
    nutgrass Guest
    a little expensive if they do go though
    Jul 2003
    One thing to consider is whether your vehicle will comply with ADR and therefore Roadworthiness. A higher wattage set might not.
    It's not something that is tested, in NSW at least, for annual registration (not yet anyway).
    Just getting your existing lights to work at their optimum output might be improved with a loom upgrade alone and maybe also some improved output lamps like Osram 50+. This won't generate significant additional heat.
    If you want more then additional spotties will help.
    Have a look at the www.narva.com.au site for stuff they label their stuff according to ADR compliance.
    I don't know about impacts on the system that might come with the more sophisticated electronics as I am driving second generation Fred Flintstone technology :wink: .
    I guess you have been following this thread:
    http://www.aulro.com/modules.php?name=Foru...iewtopic&t=4714
    Mahn England
    Ex 300Tdi Disco:
    nutgrass Guest
    Yes I have followed the thread mentioned.
    Spotties not a problem, just the low beam issue.
    will look at loom I think as had big gains with s2 disco previously
    Jul 2003
    Start with higher performance lamps then next the looms.
    If you have access to a lux meter (~$40 at www.dse.com.au) and a wall at a measured constant distance and ambient light levels you can measure the before and after improvement at each stage.
    Mahn England
    Ex 300Tdi Disco:
    SYDNEY -in the shire.....
    Originally posted by one_iota+--><div class='quotetop'>QUOTE(one_iota)</div><div class='quotemain'><!--QuoteBegin-nutgrass
    If you have access to a lux meter (~$40 at www.dse.com.au) and a wall at a measured constant distance and ambient light levels you can measure the before and after improvement at each stage.[/b][/quote]
    $48.64....i found it on their site..i gotta invest in one now...
    http://www.dse.com.au/cgi-bin/dse.storefro...duct/View/Q1367
