Results 1 to 10 of 15
Thread: Dead speakers and Audio Upgrade
    Feb 2013
    Gosford, NSW, Australia
    Hi
    I began investigating my speakers and discovered some pretty ugly things!
    Subwoofer driver (early type with single driver) surround is totally perished
    Mid Range drivers, 3 out of 4 had warped cones.
    Woofers, drivers side completely seized.
    So i have replaced all the mid-range drivers with Visaton FRS7's, as per Hoges suggestion
    The subwoofer driver is a 10" dual coil 4 ohm driver, impossible to replace
    The door woofers are 6.5 inch nominal. The frame which holds them is 166mm diameter or a little larger.
    The best fit I can find so far are these
    https://www.madisoundspeakerstore.co...1/2-wool-cone/
    The Visaton 6.5 inch ones are actually a 187mm diameter frame
    http://www.soundlabsgroup.com.au/p/V-9024-
    W170S/W+170+S+-+4+Ohm
    So unless I can find something else the silver flutes will be going in
    Pic of some of the old speakers attached and yes that is a see through hole in the subwoofer surround!
    Steve
    Feb 2010
    Townsville, QLD
    My speakers and woofers were replaced with Polk Audio 6.5" units. All up cost about $300 and came with a driver for each. They also came with tweeters.
    Got them from Autobarn.
    Keithy
    Feb 2013
    Quote Originally Posted by Keithy P38 View Post
    Keithy
    I thought about the coaxials but decided to try to keep it as a three way system
    Most of those coaxials sound pretty good though!
    Steve
    Steve, FWIW I resurrected a pair of 10" drivers for a stereo using new surrounds I obtained from "Speaker Bits" . The old ones were worse than in yr photo... The kit came with glue included and a set of instructions on how to align the driver with the magnet... quite satisfactory outcome for fraction of price of replacement speaker. I also refurb'd the two base drivers in the p38's subwoofer similarly.
    Feb 2013
    Quote Originally Posted by Hoges View Post
    Hoges you are a man of many talents
    I thought about a recone as well, I has some Mordaunt-Short drivers reconed by SPEAKERWORKS Australia and they sound great.
    The original door woofers are nothing special so I think replacement is a better option there.
    I have decided I would rather have the space tan the subwoofer and I'll probably go with the kenwood KSC-SW11 as I did with my other rangie.
    Quote Originally Posted by TheTree View Post
    Maybe: http://www.speakerbits.com/index.php...d=7&Itemid=110
    Feb 2013
    Well I went for the silver flute woofers and they arrived in quick time from the US.
    They are indeed a perfect fit in the original mounts, so it is basically the same as what Stefan did on the stockholmviews web page, except I used nuts and bolts with a dab of permatex blue to stop them vibrating loose. I wouldn't trust self tappers there, nuts and bolts are however a fiddly two person job
    It sounds pretty nice I must say
    Next step is to replace the tweeters and put a proper crossover in the hollow behind the door handles.
    <GEEK>For the audio geeks I am using a second order Linkwitz-Riley crossover at 6K, the FRS7's are a "full range" speaker and they have a bit of a lump at 10K so I want them well attenuated by that point. </GEEK>
    I have added a couple of pics to show the new woofers mounted and a comparison between the new and the old to show the difference in magnet size.
    I am also going to add subwoofers back in at some point
    As well I have wired up a noise free connection for an aftermarket head unit, using the Nexxia kit. As Ron said in a thread on rr.net the original Nexxia lead would never work without buzzing and noise. I will make a separate post about that.
    Steve
    Feb 2010
    Townsville, QLD
    I'm interested in the "noise free" bit you mention - I'm a bit in the dark with this as I'm still running the factory head unit.
    I was thinking about putting a separate head unit in the rear, run off the aux battery through all speakers, used for camping (with the benefit of being able to use it over the factory unit for Bluetooth, etc while driving).
    Would I experience noise if I were to do this just as a DIY type setup?
    Keithy
    Feb 2013
    Keithy
    Mate
    Since you have a MY99 with the alpine head unit the nexxia lead will work just fine.
    Edit: Nexxia says you don't need an adaptor lead at all, which I now remember is true, but you still need the attenuator or at least I did because the volume control was way to sensitive. I think some of the better units have an output level control
    one of these from supercheap is 299
    Kenwood KDC-U563BT
    And of course you still need an adaptor lead, i'm pretty sure this is the one
    Aerpro Wiring Harness - APP8KE1, to suit Kenwood 2005 on, 16 pin plug
    This is what I had to add to my My99 by cutting into the adaptor lead;
    http://www.rangerovers.net/rrupgrade...unitadapt.html
    If you don't want a screen you can get kenwood, pioneer etc with bluetooth which is excellent.
    Wiring a head unit in the back into the car system would be a nightmare I reckon
    You could of course run a head unit and a pair of speakers in the back totally separate from the factory system
    Steve
    Feb 2010
    Townsville, QLD
    I already have 12 speakers to choose from though!
    It was just a thought I guess! Would be good, that way I can keep the factory unit (I quite like the look of the standard unit).
    I was going to splice it into the speaker-outs from the factory head unit and be done with it, seems it may be more work than that! A separate unit and two speakers in the rear might be easier!
    Keithy
