Thread: TD5 Binnacle switches
    Apr 2015
    Greenwith SA
    I have a 2002 TD5 an i'm trying to work out what the extra connectors into blank facia switch in the binacle are?
    Currently I have rear fogs on the left and rear washer, rear wiper, cruise control on the right.
    Any Ideas?
    May 2014
    Point Cook, VIC
    On the left you can also have front spots, plus front fogs. On the right the D2a also had fuel flap release (relocated).
    Apr 2015
    Greenwith SA
    So the wires which are there currently would be for front fog (which I expected) and front spots?
    Next question, any ideas where the connection are in the bonnet for the spots? I have found the fogs but not the spots?
    For referance my fuel release is to the right of the climate control unit
    Jul 2014
    west of Transylvania
    It's normal for 2002 modell to have the fuel flap button where you have it, only facelifts have it on the binnacle(or maybe some very late 2002 - early 2003 tranzition prefacelift modells)
    There are only two modells of binnacle switch factory setups, for prefacelift and facelift modells, if you find plugs under the blank switches those are for the systems which are fitted on the facelift modells but in most cases it's only the wiring, the relays(if needed) are usually missing, the only thing which should be there under a blank plug is the cruise control circuit where it wasnt fitted
    No factory setup for spot lights so dont search in vain, see attachments
    Actually there is, but there is no factory fitted wiring it comes in a kit, switch and wiring.
    See, RAVE doesn't have all the answers. Parts book and exploded diagram are just as good re service as they have part numbers and exploded diagrams.
