Results 1 to 10 of 14
Thread: Lightweight grinder recommendations
    Nov 2014
    Melbourne, Mount Waverley
    Hi all. I am looking for a lightweight grinder to use removing small areas of rust and/or corrosion and for polishing metal surfaces on a Series IIA. I have an industrial angle-grinder but even with a wire brush fitted rather than a disc it is pretty aggressive. I was thinking one of those Dremel or Ryobi type devices might be sufficient. It doesn't have to be cordless. They do seem to have an accessory head for every damn thing (including whipping up a cappucino I imagine) so it could have some application in my wood working as well.
    Any recommendations on this tool type would be gratefully received.
    Damian
    Feb 2014
    What about an air tool?
    They are available in straight shaft or offset (great tool for light derusting), light, cheap, small and reliable. They don't use much air so only a small compressor is required.
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Nov 2014
    Lot of extra expense though isn't it Phil
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by damiane View Post
    $20 going to break the budget? Ozito Air Straight Grinder Kit AGK-PRO I/N 6290425 | Bunnings Warehouse
    If you don't have a compressor, then that's a great excuse to buy one of them too! . It's a must have for any workshop and they aren't expensive for little hobby versions.
    One of theses would be much more suitable than a Dremel. I have one and while it's great for very small stuff and model making, it wouldn't cut it doing anything on a vehicle.
    Shepparton
    Quote Originally Posted by bacicat View Post
    I have an SPC straight air grinder and a more expensive (can't remember brand) 90deg shaft. Comparing the two the more expensive one (was around the $150mark) is more efficient and has more grinding power. I use the 90deg one a lot more than the straight shaft as it is easier to hold and control, but the straight shaft will get into places the other doesn't.
    I also have a Dremel, and have used it a lot on the vehicle I am working on. I have used it to cut out small areas of rust that I could not get any other tool to do, have cut out small shapes of metal and shaped them to weld into place, ground out small divets that other tools could not get into. What I am trying to say is both have their place while working on vehicles.
    BigBlackDog Guest
    Don't you see though? You buy the compressor and the grinder. That's ok. Then you think I might as well get a tyre inflator, then an air gun, maybe a rattle gun, ooh a sand blasting cabinet! Then perhaps a paint gun. Then your cheap air compressor will either be inadequate or will blow up. So the cycle goes. And that's why a flat out refuse at this point to buy a compressor
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by BigBlackDog View Post
    Very true. Once you get a compressor, it's uses just keep on coming. When I bought mine, I lashed out and spend some decent dollars on a 17CFM trade quality unit. Over $1000 - Aussie made (when you could still buy those things) but you get what you pay for. It does draw 13 amps though and makes the lights go a bit dim when it runs, but I can - and do, anything with it including spray painting and die grinding. It will lazily work away all day without batting an eyelid. It's got the grunt to do anything I will ever need. Probably why I leave the Dremel in its case when I'm working on cars, it covers all my needs.
    Jan 2015
    Mt. Eliza
    Yep, compressor and air tools, I only use a dremel for small finicky jobs.
    Nov 2014
    Grinding me down
    Okay thanks guys for the contributions thus far. I get it. Dremel has limited use for the task in hand. Compressors are king but will rule your life for ever after and will also cause power outages in all surrounding suburbs. So clearly given that the bit that fits on the almost end is $20 and yes Gav I can afford that - just - what about the cost of the huffy puffy bit. At what point am I no longer ripping up money and am the proud possessor of a staunch DIY level compressor. Note: maybe there is a forum somewhere for compressor owners who do restorations on old compressors. The mind boggles.
    What about this 90 degree versus 0 degree stuff. What will prove the most useful when I am on my back under the chassis spitting out 40 year old rust and mud from the High Plains winter of 1976. Any recommendations as to brand of compressor, HP, puffnpower, etc.
    with thanks for your guidance
    Damian
    Feb 2014
    As the others have said air tools are relatively cheap and the types of tool function is endless. Once you start you will go on to buy them all they are that good.
    Cheap tools are OK (except rattle guns in my experience) but buy a good compressor and it will last a life time.
    17 to 20cfm is the right size. It is the free air pumped volume you are looking for, in other word what volume the compressor will pump with the outlet valve open to atmosphere. The more the better. Horse power is linked to cfm. Tank size doesn't really matter except when you are seriously spray painting. There is nothing worse than running out of air when painting.
    Consider a second hand unit on evilbay or the like. If you take your time good units do come up. Just watch out for the cheap stuff. It will not produce the cfm.
    Phil B
    Custodian of:
    1978 S3 swb canvas
