Results 1 to 10 of 20
Thread: what makes a defender 3500kg GVM?
    Jun 2012
    Beechworth
    Hi all, I'm have an 1984 Isuzu 120 tray that I'm about to get engineered as I've changed it to a six seater dual cab and it also has air suspension. It's current GVM is 3200kg, and since I'm getting it engineered anyway, I thought I'd get the GVM upgraded to 3500kg as per current 130's. I've spoken to the engineer and he says that if I can prove that mine has all the same up grades as the factory 3500 GVM defenders he will sign mine off. it has had a rear disc brake conversion.
    So to convince my engineer, what do the 3500kg gvm defenders have that the others don't? Might need some official document to back it up also.
    Andrew.
    Western Victoria
    I'm wanting to get the GCM rerated on one of mine.
    The GVM is predominately based on axle weights. i.e. what the axle and suspension can be loaded to.
    Jun 2012
    Beechworth
    Quote Originally Posted by Mick_Marsh View Post
    Yeh your right about the axle weights, so why do defenders with the same axles have different GVM? Stiffer springs, coil in coil for 130's?
    Aug 2011
    Stanwell Park, NSW
    666.1 KB
    certainly in the Puma range the 130 has heavier duty coils to the 110 variety. The 110 fronts are 185 lbs/in (i think from memory) and the 110 rears are 330 lbs/in. The 130 fronts are 225 lbs/in and rear 270 progressive to 420 lbs/in + the inner helper at 140 lbs/in.
    When I fitted HD coils to my 110 the engineer revised the GVM to 3500 kgs.
    Not sure how you will go with air suspension, manufacturer's specs will be the answer I suspect.
    MLD
    Jun 2012
    Beechworth
    Quote Originally Posted by MLD View Post
    MLD
    Thanks, was just thinking that, I'll have to see what the specs are for the air bags.
    Near Seven Hills, Sydney
    All hearsay...
    130 sals are supposedly thicker walled or reinforced compared to 110 (and 120 I suspect) sals.
    130 chassis (early on at least) were supposedly thicker than a 110 chassis as they used an extra layer of material somewhere.
    130s came with HD rims that 110s didn't come with standard from the factory.
    You may also note that the Puma era cab chassis, Hi-Cap and Hard Top 110s could be optioned with the HD pack, that's basically what you'll need to meet i'd reckon.
    Jun 2012
    Beechworth
    Quote Originally Posted by isuzutoo-eh View Post
    All hearsay...
    Ok, so anyone know what the HD pack consists of?
    The 110 Hardtop, Single Cab Chassis and HCPU models have two options; the Boost pack of alloy rims, traction control and ABS, or the Heavy Duty pack of a reinforced chassis, steel rims, Michelin XZL tyres (very strong light-truck mud tyre designed for extremely heavy loads), coil-within-coil rear springs and a GVM increase of 450kg to 3500kg, same as all 130s.
    from post 4 in this thread:
    Reinforced chassis
    Jun 2012
    Beechworth
    Talking
    Reinforced chassis
    Thanks for the link to the old thread, had a look and nobody got to the bottom of the reinforced chassis upgrade, mine is a 130 chassis so should be ok. I do have the wolf rims and hopefully the airbags are rated high enough so should be ok. Not sure what Salisbury diff I have, will check for markings to see if it's the heavy duty type.
    Do the so called HD Salisbury diffs actually have a higher load rating than the standard Salisbury diffs? 2200kg I'm pretty sure.
    Is the factory, heavy duty, upgrade for the 110 recorded in the VIN for that vehicle?
