Thread: Alternator not charging after Burst pipe incident.
    Mar 2015
    denmark
    Hi All,
    After the thermostat housing blew on my landy (cause was rust)
    Which is now fixed with an aluminium welded pipe.
    I start it up and runs well but alternator not charging....
    why....? why would this go at same time.!? ive cleaned connections, tightened belt...
    and get this Izuzu dealer quoted $2000!!!!!!!!!!!!!
    Part number from all4x4s... 8941754481.
    Any help much appreciated.
    slip rings not making contact, sense wire connection gave up with the dousing/heat
    Aussie Expat in NZ
    check for lose wires as well...
    There are other non-genuine alts that are available that cost a whole lot less than 2k. if you search around on here and in the part numbers sticky thread you'll be able to get one for a few hundred.
    Mar 2015
    denmark
    Found one with extenal regulator and was $490 inc.. still alot of money but least landy back on road now.
    Was abit of a nightmare but thanks for help with sticky etc.
    Welded ali thermo housing up and cost $60
    fingers crosed no more bills for a while. skint
    Jul 2012
    Gaborone, Botswana
    There's a company (hc cargo) in Esbjerg, if I remember correctly, that makes rebuild kits (slip ring, voltage regulator, rectifier and bearings) for some alternators, so you may be able to rebuild your old unit and keep it for a spare. P?j p?j.
