Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: Diesel Additives
    david7307 Guest
    Diesel Additives
    Going to be doing an oil change and fuel filter change this weekend,and was wondering is it worth putting in a diese additive to clean injectors or is it just a waist of time, there is no smoke from exhaust, and if thy work what is a good one to use
    thanks
    Apr 2015
    Hervey Bay
    It really depends if your fuel system is dirty. If it isn't it will have no effect. If it is gummed up it might be good.
    I remembering seeing a 5th Gear program on restoring power to older cars and the fuel system cleaner gave the best increase in power for five'r than anything else they did.
    Anyway at $15 bucks it can't hurt.
    Nov 2008
    seaham (gods country) nsw
    The best additive IMO is the Chemtec diesel power, not sure how much power it gives you (probably nothing) but keeps the algae from growing in your tank.
    Tangus
    1925 - Trojan Utility
    1973 - jaguar XJ6
    1980 - Series 3 FFR
    1980 - Series 3 GS
    1998 - 300tdi 130
    Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
    Normanhurst, NSW
    On a 23k km trip some years ago, I noticed the fuel consumption dropping off after about 7k km. After dosing with Nulon diesel injector cleaner, the consumption would improve significantly.
    Since then I have been dosing every second or third fill, figuring that it's best to keep injectors performing well all the time.
    I've only used the Nulon product so can't comment on the others.
    Roger
    Sep 2009
    Quote Originally Posted by david7307 View Post
    thanks
    I use cleanpower (and other products) from costeffective.com.au. Per dose its cost effective (sigh) compared to other additives. (High initial cost). I believe fuel economy is better when I use it, but I don't record the data. Sorted out issues in an older diesel as well. Recommended to others who have had good results as well.
    Jan 2011
    Gippsland
    I dose every fill with a diesel additive but there have been periods where i didn't for one two or three tanks in row and my son (who's always following ) say's it smokes less on the additive and cos i do record the fuel economy i can verify that the difference is 2 > 4 litres / 100k.
    onebob
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Nov 2014
    Nirvana near Albany W.A.
    Quote Originally Posted by onebob View Post
    onebob
    Really ,onebob 2 > 4 litres /100k
    So up to 1400 kilometers to a tank , what additive would that be?.
    May 2014
    Point Cook, VIC
    The other alternative to adding your own additives is to run a tank or two of BP Ultimate Diesel every so often. I know specialist BMW and Audi Indies who swear by it in high tech turbo diesels and say you can see the difference when doing repairs with less carbon build up.
    Do your own research and make up your own mind. If you are into adding additives, then going with the fuel companies mix can not do any harm.
    I personally like to chase the lowest cost diesel (but no bio-diesel thanks), but if running low and passing BP then will get a tank of BP Ultimate Diesel. Again could be another form of Placebo......
    Jan 2011
    Gippsland
    Quote Originally Posted by discorevy View Post
    just commonly available additives - when i plug in the figures sometimes the calculator says 14.xxL/100kms (not good) and sometimes it says 10.xxL/100kms(excellent) and most times somewhere in between
    LROCV member #131
    Dec 2009
    Baldivis WA
    Quote Originally Posted by DiscoDB View Post
    Your not far from cheap BP fuel.
    BP in Waikiki are generally the same price or sometimes cheaper than Shell Coles or Woolworths Caltex even with their 4c discount.
