Thread: Clutch
    Mar 2014
    New Zealand
    Clutch
    Ok so I went to drive the Landy today, and the clutch pedal has no resistance. So clutch doesn't work. The clutch was fine when I parked her up middle of the week. Should i get the AA to drop it off to my mechanic? Any ideas.
    Rgds
    Paul
    I had the same response when my slave cylinder failed, new slave cost me about $40 but was a real pain to put in, a pressure clutch hose also blew after that which gave a similar response, I would fill up your resoirvour get some on the peddle with you under the car with a torch to see if there is a leak in the hoses or possibly a leak in the slave gaskets
    Jun 2014
    Waitakere, New Zealand
    Haha Paultan, I've got a leaky slave as well. Just waiting on the part to be delivered.
    Mar 2014
    New Zealand
    Thanks guys. Will have a check in the morning.
    Dec 2011
    North west NSW
    As they said slave cyc.
    Hard to tell just by looking but my guess would be if you undid the wading bung on the bottom of the bell housing fluid will dribble out.
    Watch a YouTube vid or 2 before jumping in, I can't remember what but something is pretty important...
    Sorry I couldn't be anymore help.
    clutch pushrod retaining clip and locating the pushrod is what you're worried about on a slave cylinder replacement
    b
    Mar 2014
    New Zealand
    Have removed the old cylinder, it certainly looked past it's best. Interestingly there was no dust cover on it. Have a replacement and will try to fit it this weekend, if the rain stays away !
    Cheers for all your comments.
    Rgds
    Paul
