Results 1 to 4 of 4
Thread: TDV8 Engine oil, what's being used?
    Sep 2012
    Perth Australia
    Hi Guys,
    Wondering what engine oil Others are using and recommend, the only oil I know siutable is the castrol magnatec Proffessional A5 5w-30, and only available through the dealer. I once managed to order it through supercheap but recently told by a castrol rep that they would get into trouble for selling it as it is licensed and only available through dealers.
    NSW SW Slopes
    I buy it in 20L drums from my local Castrol distributor.
    Adelaide - Torrens Park
    I use a Caltex 5w-40 full synthetic, C3 rated (not that it needs to be). I change it every 10 000km (which is probably overservicing, but oil and filters are cheap).
    Make sure you drop both the drain plugs out. I replace mine every second oil change.
    Brisbane, Queensland
    I use magnatec every 10,000 km on my RRV tdv8.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
