Thread: 4x4 gear stick
    Apr 2015
    Victoria
    4x4 gear stick
    Hi guys I just recently got a 4x4 cargo perentie from frontline machinery and the 4wd geer stick knob is missing.
    Could someone help me out on where 4wd is and if anyone could tell me where to find one.
    Cheers landymancan
    Near Seven Hills, Sydney
    Hi Landymancan,
    To engage 4WD, you use the plunger switch on the dash just forward of the main gear stick, marked as 'cross country'. This can be used in high or low range, whenever traction is likely to be imperfect (gravel/mud/rocks/snow etc). A warning light on the dash will blaze starkly at you when engaged.
    To engage low range, the stubby lever is pushed forward, there isn't much travel in it but there is a neutral position in the middle. Make sure you are stationary when changing range until you are familiar with the vehicle and its nuances.
    Oct 2008
    Heart in the Deep Nth of FNQ,Body in the Deep Nth of Brisneyland
    G'Day LMC.
    Specifically, the Perentie is a constant 4x4 with selectable Centre diff lock.
    It is the same system used in older Range Rovers. Still reliable. Note that you can still be stuck with wheels spinnning, it is just a little harder to do.
    IF you are confused by the lack of gear stick, it seems you need a perentie crash course in understanding what you have laid your hard earned cash on.
    Dave b (the owner/operator of this site) has put together a great set of info here: https://www.davesitshop.com/emporium...ection-p5.html
    If you need a bit of history and ins and outs of the Perentie vehicles, I have a buyers guide available (see link in my signature).
    Cheers, BDave.
    Replace "You are...!", with "Are you...?"
    Army Land Rover Buyers Guide.
    buymilitaryvehicles.com
    Reunited with RFSV 51 680, 'Sleazy'!!
    '00 VeryDisco TD5 Auto,
    Nanocom Evo for D2 TD5 and Puma
    Gone:RFSV, 51-699, Carryall 48-358.
    JDNSW's Avatar
    The Perentie is full time four wheel drive, so there is no four wheel drive as such - just high-neutral-low.
    Can't help with where to find a knob - if the same as the civilian ones, and even if not, then one of the Melbourne Landrover specialists should be able to help. Give Fred Smith Automotive a call is one.
    Feb 2014
    Queensland
    We have the Genuine ones in stock PM for pricing.
    Apr 2012
    samford
    Smile
    Quote Originally Posted by Barefoot Dave View Post
    G'Day LMC.
    So probably a lot safer on Wet roads and dirt country roads than say a Hilux or Triton..
    Oct 2008
    OK, Just re-read the OP. It is the knob for the high / low range stick you need?
    As Justin replied in the other thread: Landybitz.com
    Cheers, BDave.
