I've done the install for a few and the consensus seems to be good if you don't tow or run larger rubber.
The tdi needs a little fuel pump massagery and I suspect the td5 would be ok up to about gvm and might support a small trailer without needing to be chipped up but you might want it just a little fatter in the low to mid rev range just to help it hold fifth a little better on hills and headwinds
