Thread: Timeing cover coolant leak
    peat Guest
    Anybody got a ballpark figure on what it would cost to repair or replace timeing cover that is leaking coolant on 3.5 V8.
    Thanks,
    Peat.
    May 2002
    Heathcote (in "The Shire")
    Pull the water pump and repair it with one of the two pack fillers, the metal putty type. I'm assuming its gone between the two heater outlet pipes.
    I did my old Rangie around 10 or so years ago but buggered if I can remember the name of the stuff. Worked a treat though.
    Bushie
    Defender200Tdi Guest
    Graeme Cooper sells refurbished front covers:
    Front cover - (ETC7385R)
    Repaired front V8 engine cover.
    These covers first get welded up where the corrosion has gone through then a extra hard
    ceramic coating is sprayed over the insided surface to help prevent it corroding through again. These covers are sold with out the oil pump & are exchange. Most comon on 3.5lt engines in classic Rnage Rover County & Series
    1 Discovery
    $385.00
    http://www.lrexpert.com.au/main.php
    Paul [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Rovernaut Guest
    Since you are in Melbourne, try Toorak tractors in Braeside . I bought a later model Timing case cover 3.9 litre for $120 , other places wanted $380 second hand!
    It takes a day to do your self taking your time.
    If like mine lots of fiddly bolts to remove from PAS bracket etc. Crankshaft pulley etc. Done it twice now so it's not hard. [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    Padstow NSW
    hey rovernaut,
    mines doin the same thing, could you post the phone number for
    toorak tractors?
    if i can get one for 120 bucks then i wont bother fixing mine.
    cheers phil.
    <div class='quotetop'>QUOTE</div><div class='quotemain'>Since you are in Melbourne, try Toorak tractors in Braeside . I bought a later model Timing case cover 3.9 litre for $120 , [/b][/quote]
    Rovernaut Guest
    Originally posted by discowhite
    hey rovernaut,
    toorak tractors?
    cheers phil.
    [/b][/quote]
    30 Tarnard St
    Braeside, Vic.
    03 9587 2866
    St Helena,Melbourne
    4.28 MB
    I took mine off and got some one to weld it up for me and then i set it up in a milling machine and cleaned up the water pump mounting face. The welding cost me about $30, any boat welder can do it.
