Results 1 to 8 of 8
Thread: Upgrade Options
    Brissy! No flannos here!
    Upgrade Options
    Hi all,
    I am currently working in Melbourne and I want to upgrade the desktop at my family home in Brisbane. So that's my first challenge!
    Ok, the second challenge is that I know little about such things, so could anyone suggest some options to upgrade the following (if it's at all possible):
    Gigabyte H55M-S2H MOBO with Intel I7 CPU 860 @ 2.8GHZ
    4GB 1333 Memory
    ATI Radeon HD 5700 series Graphics Card.
    Any suggestions? Tips, Tricks?
    Ralph
    May 2003
    On The Road
    what is it used for?
    video editing?
    spreadsheets?
    youtube?
    nearly always the easy upgrade is a better video card(PSU?), though 4gb of ram is a bit of a concern ,,
    Sep 2012
    Adelaide Hills
    if you build a new computer, this might help
    Logical Increments - PC Buying Guide
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Quote Originally Posted by Ralph1Malph View Post
    Hi all,
    4GB 1333 Memory
    Ralph
    Theres a bloke on this forum who messes around with computers a little...
    Hes a nice fellow, if not a little eccentric...
    Paging Mr Incisor... Mr Incisor to the Service Counter please..
    BTW... The easiest and cheapest benefit to a PC...
    RAM, RAM and MORE RAM..
    Sep 2012
    Adelaide Hills
    not when you have 32gigs of it
    Current Cars:
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    Apr 2015
    Bondi Junction
    Hi all,
    4GB 1333 Memory
    Ralph
    I build PCs for a giggle, and if I was in Brisbane I would do it for you.
    Firstly, would need to know what you are going to use it for - if you aren't playing games then upgrading your GPU (graphics card) is pretty pointless.
    Next, Tombie is right about the RAM, get more of it if you want a cheap fix. If you are running windows 32 bit (any windows 32 bit) then no point cause 32 bit has a useable ram limit of 4gb. If you are running 64bit windows (right click on my computer and properties, then under operating system) then go out and get more RAM, just make sure its the same frequency as your current.
    If you want to upgrade your CPU, then I would need to look at your motherboard and know what type it is so I can recommend the right one. Alternatively, you can do a mild overclock, but would only do that if you had some semblance of an idea.
    The other piece of the puzzle is your PSU, if you overload it it won't power anything and your PC will crash.
    Fill in the blanks to the questions above and I will reply back with my best advice, and a bit of advice on how to get the most out of it.
    This is taking into account you have already done the obvious, remove all programs you dont use, defrag it and open it up and clean out the dust etc (computers are electrical, the hotter they are the less conductive the parts which means slower).
    Joe
    Sent from my SM-G900I using AULRO mobile app
    May 2003
    On The Road
    Gigabyte H55M-S2H only has two ram slots,,
    you could (only)double your ram for less than $100,,
    the graphics card is around 5 years old, still, it is a DX11 so dont bin it,, yet.
    an AMD R9 270X will run you around 2 hundred,,
