Thread: 2005 Megane 16v 2.0 crank pulley replacement
    Feb 2009
    Newborough, VIC
    67.72 MB
    Question 2005 Megane 16v 2.0 crank pulley replacement
    Hi all,
    I've had some good advice on this site in regards to my Renault, so I'll try my luck again.
    The crank pulley (harmonic balancer) is u/s and needs to be replaced, but I am not sure I can simply pull the old one off and bolt the new one on.
    Someone suggested to me that the timing can be thrown out by removing the pulley as there is no keyway.
    It is very hard to find reliable info on this, so any help would be greatly appreciated.
    biggin
    2002 D2 4.6L V8 Auto SLS+2" ACE CDL Truetrac(F) Nanocom(V8 only)
    Feb 2009
    Newborough, VIC
    67.72 MB
    Yeh. I don't know either.
    Davehoos Guest
    I replaced an air conditoning compressor. The belt was wrapped in behind the crank pulley. bit of a no thinking about it job. I did a google and it came up with lots of different pictures of lots of versions.
    The pulley I replaced came from a wrecker and had Volvo on the tag and no timing marks.
    Feb 2009
    Newborough, VIC
    67.72 MB
    Yes there are lots of versions and that's what is worrying me.
    So you replace the crank pulley? Did you have to worry about timing, or did you simply unbolt the old and bolt on the new? Was it easy to get off?
    Feb 2013
    Ballarat,Vic,Aus
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
