Thread: Discovery TDi Roof bars
    Hobart D1 Sydney D4
    Gday
    Has anybody removed the standard LR fitted roof bars on their Disco. I have a 1997 Tdi SE7 with the standard bars fitted and due to limited garage door height, I wish to remove them. It would appear I will need to remove the roof lining and then get at what ever fittings hold the bars on. Any ideas and/or comments appreciated.
    Also does anybody want / need a pair of rear Disco seats (side seats) from a SE7?
    I'm in Tassie and will be removing them shortly to fit a set of draws etc.
    Oct 2003
    Gold Coast, Qld.
    i was thinking of removing it but after a closer look i think i cam to the conclsion that the roof has an arc in the centre which is only just below those bars so i think they are more there as a protectant than anything else.
    But am probably wrong 8O
    RAAF Tactical 200184 & 200168
    Sunny Coast
    go to http://www.discoweb.org/ click through to tech section and browse down to "roof rail removal" (cant seem to link directly due to frames :x )there is a pictorial guide there
    Oct 2003
    Gold Coast, Qld.
    I have recently put on roof rails on my Disco 1 - you need to remove the window pillar trim, grap rails, trim around the seat belts - not all that hard to do - very, very carefully pull the headlineing down a bit and you should be able to get at the nuts that hold on the rails - they dont actually bolt to the roof panel but a reinforcing panel inside the roof.
    Once the rails are removed, what do you intend to do with the four holes in the roof - suppose those old fittings to cover up old aerial holes will do but it will look a bit odd.
    Hope this helps
    Gazz
    I'd Rather Push My Land Rover in QLD Than Drive A Toyota in NSW
    Hi MikeL,
    Check out expedition exchange site they have a full blow by blow description of how to remove and the size plugs to firt the holes and all.
    This is the link.
    http://www.expeditionexchange.com/roofrails/
    Very well explained.
    Glen.
    british4wd Guest
    Rear seats
    Mikel,
    Would you please contact me re the rear seats Ph. 03 6234 9444
    Alan Howard
