Results 1 to 9 of 9
Thread: tubeless rims for Perentie 6x6
    Jul 2014
    Gold Coast, Qld
    helping my dad, decide if he should change to tubeless rims for his perentie 6x6.
    are the wolfrims the only HD option ?
    we've read a 1000 posts on tyres lately.
    Jul 2011
    Yarrawonga, Vic
    Best of both worlds,
    Michelin have inserts that you can put into a split rim to run tubeless tyres.
    the Breach T-Rex and Iveco Daily 4x4 run XZL 255x100R16 on 16 x6.5 split rims , yes tubeless.
    Western Victoria
    The Perentie rim is not a split rim (although some do have). It just does not have the tubeless ridges for the bead.
    Does this Michelin insert cater for this? A link would be handy.
    Jul 2011
    Yarrawonga, Vic
    I was thinking he had the Split Rims,
    otherwise Ive always run the non-tubless one piece LR rims tubeless anyway . The michelin seal is just to run tubeless on split rims, and they don't have the safety ridges either. but 100% legal.
    having trouble finding link - will look up Iveco parts book and get back to you
    East-South-East Girt-By-Sea
    1.20 MB
    Its interesting back in the olden days when tubeless tyres were becoming common tubeless tyres were fitted to standard rims. The rib was not a requirement as the angle of the bead made the seal. In fact in Holden cars, the ribbed rims were called "safety rims" without any reference to tubeless.
    The first Range Rover (classic) alloy rims were actually labeled tubed. The subsequent MY86 alloys that looked identical were labeled tubeless.
    Being pragmatic, the only rims that shouldn't be used tubeless are rivetted rims or rims where there is damage around the valve hole.
    Western Victoria
    There used to be a company called "Peco Star" that was bought out by "White Systems".
    They made a custom sunraysia style rim. Each spoke was double welded to the rim.
    They are the sort of wheel you should be looking for. You should find a manufacturer if you ask around the off road racing scene.
    http://www.wheeldictionary.net/13/pecostarxx13.jpg
    Looks as if Eastern Wheel Works are making them now.
    Wheel Repairs Melbourne, Custom Wheel Builders including Rangerovers, Landrovers and Subaru
    Queensland
    Still, lots of people on here including me are now running tubeless on rivetted rims.
    Mine are running 255-100-16 on the 130 6 1/2 inch rims no problem.
    Jun 2014
    Waitakere, New Zealand
    I know its not a 6x6, but Wolfs work well
    Good post, I was also looking for 2 for the front, as the back would be fine on tubeless.
    Bearman said to me some time back that he has run tubeless for awhile .
    I have 2 running tubeless on the back with no probless so far ,its just the thought ...
    Bob...
