Results 1 to 4 of 4
Thread: Single roof bar for D3
    Hunter Valley, NSW
    Hi there - I have the standard roof rails with LR racks - all good, but I've heard that I can purchase a single bar to attach to the front roof holes to accommodate an awning support - meaning a bigger (better?) awning without the need for a new set of extended roof rails.
    Is this the case and if so, where do I purchase?
    many thanks in advance!
    2016 Firenze Red Disco 4 TDV6
    2018 Firenze Red Disco Sport
    ... plus many previous!
    Oct 2013
    Old Toongabbie, Sydney NSW
    HI hiker.
    Try this thread.
    http://www.aulro.com/afvb/d3-d4-rrs/...tion-roof.html
    Several entries down there are posts about a third rail.
    Martin
    Hunter Valley, NSW
    Thanks Martin - so rumours are true! I'm on it!
    Dec 2009
    Hi,
    If you are intending on going down the same path as I did in that thread, you might need some taller spacers than the particular ones I used. This is because the Rhino rail is lower than the OEM rail, and the Rhino sports cross bars are also a little lower than the OEM bars.
    I am sure they can find the right height spacer to give you a front bar that will be nice and level with your existing ones, but just something to check in case you were going to order parts yourself.
    Cheers!
