Hi Matt, as long as you do not have an auxiliary battery in your tug, that will work.
But if this is to be in regular use, and you want to charge the camper battery from a low state while driving, I would suggest you go to 6B&S ( 6 Gauge ) cable.
While 6B&S is only a 60% increase in the cable size over the 8B&S, it will more than double your charging capability.
BTW, if you do have an auxiliary battery in your tug, the SC40 is not capable of handling more than one battery at a time. This is why I ceased manufacturing them some years back.
