Check your cables from the battery to the starter switch and then to the starter. Also check your resistance from the engine to the chassis and battery earth. Where are you measuring full volts? On the battery or at the starter? Could just be high resistance there. Check the voltage at the battery when cranking, then take the same reading at the starter motor - they should be quite close. If not, whip it put and crack it open - it may only need new brushes or a good clean of the commutator.
