Results 1 to 10 of 11
Thread: Taller Coils or bags when towing
    Hobart Tasmania
    My D1 has 2" lift but it starts to sag when loaded as expected. It got me thinking that when ill be towing the caravan the sag will be worse. So what option (cost effective) is the one i should consider, taller/stronger coils or bags? Must admit i am looking at a cheap option, so coils are on my radar. But taller coils may cause uni probs and stiffer coils will be of detriment in off road trips...
    What have you guys done? Thoughts?
    Carlos
    1963 Land Rover Series 2a 88
    Oct 2003
    Montrose, Vic.
    Have you thought about the air bags that go inside your existing springs?
    I ran these on a D2 for a while... worked great...
    4121, Firestone Coil-Rite Rear Air Spring Kit for the Range Rover - TruckSpring.com
    Mark
    2003 D2a TD5...gone...
    2000 D2 V8...gone...
    https://bymark.photography
    Hamish3300 Guest
    Talking
    Having tried the air bags above, and the bellows type - I fall back on the KISS principle. Fitting stiffer springs, with a constant load rating that hold your vehicle at the correct height when loaded leaves you with less to go wrong - if you rely on air bags and one blows when you are miles from anywhere (which is the point of a land rover!) you are up the creek.
    Keep you usual springs to fit back in when not towing, as it takes all of 15 minutes and one spanner to change the rear springs.
    May 2003
    On The Road
    Quote Originally Posted by Bytemrk View Post
    X2...
    St Helena,Melbourne
    4.28 MB
    You could go with a set of progressive rate springs in the rear but if you are happy with them when not towing then i would go with the air bags.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Hobart Tasmania
    Thx for your comments. I will be going the bigger springs 20mm extra and see how it goes.
    Carlos
    Feb 2013
    Ballarat,Vic,Aus
    Wouldn't it be cheaper and easier to just repair the boge load leveler ................................
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by DoubleChevron View Post
    The ones that AREN'T fitted to D1's .
    1974 VW Kombi bus
    Feb 2013
    Ballarat,Vic,Aus
    How do they level then They'd either ride like crap on rock hard springs, or drag the arse up the road like a dog with worms if loaded ....
    seeya,
    Shane L.
    Proper cars--
    Modern Junk:
    May 2006
    Woolgoolga
    Boge's haven't been around since the late 80's
