Thread: Freelander - Electronic Parts/Workshop Manuals
    Hi all,
    Anyone know where I can electronic workshop and parts manuals for the L series Diesel Freelander - I have previously bought on ebay UK but even though they advertise to have L series most are V6 or TD4. The usual rip-off. They are not listed in our emporium on this sight.
    Gazzz
    May 2002
    Sydney, Australia
    I just checked my RAVE disc I bought from this very sight - cheers Inc, and it includes Freelander Worshop Mnaual version 5 and lists both L and K series engines.
    Bugger me - even has video clips!!!! Nice one about cam belts!!!
    HTH
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Thanks LRH - have the Disco1Rave on order from this site - the description doesn't list the Freelander - can you confirm that this is the disk that you have.
    Also have the parts disk on order - guess I should have looked at the description a little closer - it does mention Freelander - didn't get past Disco 1.
    Changed my timing belt at Xmas when I found out it was about 30,000 km overdue (still looked like new though) - I used a Haynes Manual - it implies unbolting engine and removing driveshafts etc - however I found that by modifiying some small sockets I could do the job without moving the engine - there is just enough room to get the timing cover off and the new belt on - not difficult, just time consuming and a bit fiddly for arthritic fingers. Beer gut gets in the way a bit too!!
    Gazz
    V8 Disco 1 update
    Freelander XEDI
    Previously V8 Disco
    Series 3
    Series 1
    May 2002
    Sydney, Australia
    yep I have the Rave: 1 Disc and this has the Freelander L Series manuals.
    The EPC also has the Freelander - but says 4 engines:
    1800 Petrol - K Series
    2000 Diesel - TCie ? Could be L Series?
    2000 Diesel - TD4
    2500 Petrol - V6
    HTH
    LRH
    Disco 4 SDV6 Auto
    RRC 300 TDI Auto
    Subaru GDA WRX
    Yamaha TTR250
    Taa
    Nanny state UK...
    Yep... RAVE covers the Freebee.
    WRT the timing belts.... The pukka way of doing them is to remove the drive shafts and move the engine over for access!!!!!
    Mark
    Mark - that sounds like too much work.
    My way, I only need the timing belt etc, no driveshaft nuts or circlip (bought a nut today from the stealer for $25) - and I only need a jack and some dexterity rather than engine hoists etc.
    This tread was a silly question on my part. On re-reading what is on the Rave1 and parts CD, I do find that the freelander is lited on it - silly me.
    Gazzz
