Results 1 to 10 of 17
Thread: towing a swan with a disco 1995 tdi
    lanise Guest
    Hello all.
    I have a question regarding towing a jayco swan camper ( 1982) with a 1995 tdi discovery. We are going to darwin and then cairns. No off road.
    However I was wondering if anyone has towed this combination before and how did it go? We realise it will not be speedy, however as long as we track along with no big hassles.
    Does anyone have any advice?
    I accidently posted this on the technical chatter forum and then realised this forum was here! sorry.
    Regards Lanise
    Ferntree Gully VIC
    mate it will do it easy [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img] [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    little slow up hills, but whats it matter :wink: :wink:
    130's rule
    lanise Guest
    Thanks for your encouragement.
    The car goes well and just changed the timing belt. However we get mixed reactions from people when we say we are towing the camper to Darwin!
    I thought that the car would cope well and appreciate your comments. Is there anything that is likely to be a possable problem ( spare parts). We have a landrover dealer here that will give us a spare parts kit for $100.00 and we just pay for what we use ( hopefully nothing). We can decide what spares we want to take. Do you have any suggestions?
    Thanks again Lanise
    Toowoomba QLD.
    We towed a 1400kg 16 ft Jayco Expanda (full height van), behind our TDi300 Auto to Darwin and back with no issues. We too changed the timing belt prior to leaving, along with the engine, diffs, gearbox and t/case oils. Fitted new fuel and air filters. (80,000 klms at the time), On some of the larger, (longer) hills I found it was advantageous to turn off the air con unit to give a bit more power. I am not sure why you would get a mixed reaction going to Darwin towing a camper! You will be one of many happy campers on the road.
    Unsure where you are, but if going via Qld, Beware the road out of Mt Isa to Camooweal, it is a shocker. Some of it is under reconstruction at present thank god! That was August 04, so more will have been done by now, hopefully!
    Trev.
    Jul 2003
    Hi Lanise,
    Good to hear that the timing belt change went well.
    Noted your post in the tech forum and also LRH's suggestion for the fitting of an egt guage.
    A low coolant level alarm is also cheap insurance. Discussed here:
    http://www.aulro.com/modules.php?name=Foru...iewtopic&t=5517
    As for spares and related to this are hoses for the cooling system.
    Also check the condition of the oil hoses from the filter to the oil cooler. The swaged connections are prone to failure. An hydraulic hose company like Pirtek can modify these so that replacement of the rubber hoses is easier, cheaper and more convenient. The standard LR issue is expensive.
    Finally as for towing the Tdi will do the job inspite of some people's belief that only a large capacity petrol guzzler can tow.
    Mahn England
    Ex 300Tdi Disco:
    lanise Guest
    Thanks for your replys they are very helpful.
    One question: How bad is the road from Isa to Camoweal? Is it narrow, broken up or all of the above? How long is this stretch?
    I had heard that this part of the road was windy and not too good, and it is great to be informed about these things ahead of time.
    We are travelling from Coffs Harbour.
    Regards Lanise
    Toowoomba QLD.
    Lanise,
    Large parts of the road are single lane so if a truck is on it you need to get off into the dirt. They cannot, as they weigh far too much and could roll over. This is I suspect the main reason for the upgrades taking place. This stretch of road is also like a roller coaster, you are constantly going up and down into hollows. I normally travel it early morning to try and avoid other traffic. There could be others on this forum who have travelled it recently and can advise on the current road condition, or check with the RACQ. Main thing on that piece of road is to keep the speed down, and be prepared to get off it reguarly. It is not a scary drive but does require a cautious approach.
    Trev.
    Brisbane, Queensland (Australia)
    Lanise,
    We travelled the road from Isa to Camoweal a month ago (April/May 2005). We went from Brisbane to Broome and return. Only 10,300km or so in five weeks. The road from Camoweal to Mt Isa needs care but the trip is not too bad. Just take it slow (80 to 90kph) and pull over to let others pass on the narrow sections. This should avoid stone damage as this was my main concern.
    Road upgrades are on the go but there seems little rhyme or reason to just which section they work on. One time you will be on a good road and then on a one lane wide section with rather nasty crests, just be prepared toslow down is my advice. I can email some pics of the road if you like. Just let me know your address.
    I am not at all impressed with Queensland Roads in general, even though I am a Qlder! They are just too bumpy compared to Northern territory and Western Aust roads. I did not come across pot holes, just ups and downs and wobbly roads.
    We towed an off road camper trailer without any problems. I have a TD5 auto.
    Have a great trip.
    Barry
    This was my last disco, a 95 TDI auto. This was taken on a trip I did from Bris to Atherton tablelands, loaded with 2 kids all there junk and enough goodies for 3 weeks (Heavy) [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
    The vehicle did the trip very well, but I have to say if its an auto keep an eye out for the temp light when going up hill, I had to back off going up the range because it started getting warm, if this looks like its going to be a problem dont be afraid to drop it in low range without CD lock on. My other suggestion is make sure your idler pulley is in good order as mine was a bit off and caused the belt to jump a couple of ribs on rough roads and ended up shredding half the underside of my bonnet.
    Also if you are not sure when the radiator was last cleaned out get it done and replace the thermostat as the motor will be getting a good workout and it tends to get warm up north 8)
    And against popular belief I overtook a few semi trailers on the trip 8O
    Series 11A ex Air Force
    1995 ES Discovery TDI
    RIP 2006 Discovery 3
    RIP 2004 V8 Discovery
    RIP 95 Discovery TDI
    RIP 1999 Freelander
    RIP 1978 EX Army FFR
    One more thing, check your line between the fuel filter and the pump, if it doesnt have alot of play get it looked at, personal experience again the pump ended up cracking where the pipes attach.
    worth a look, could save a few dramas as they tend to expose themselves on a stressful trip [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
    RIP 1999 Freelander
