I am trialing an idea to improve the gap between the bottom edge of the door and the slider plate.
The gap occurs because the factory plastic trim includes a raised profile that allows the door bottom lip to close on the sill.
The slider plate does not have a raised profile.
I have added a Trim-Lok rubber seal with a self-adhesive backing.
It seems to work but needs testing in wet & dusty conditions.
It's not meant to be an actual seal but at least be as good as the factory plastic. I guess longevity could be an issue but we'll see.
Regards,
Link to my D4 Build Thread
D3 2005 V8 Petrol
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
That looks good and there I was thinking I was clever and original
I figured it wouldn't adhere to my slider plate due to its powder-coat ripple finish, hence attaching to the door lip.
D3 2005 V8 Petrol
Brilliant.
...off to find my nearest Clarke Rubber.
I just received 8 mtrs of it via ebay - $8.00
There are a few sellers with this type
1 4 5M D Shape CAR Truck Motor Door Rubber Sealing Seal Strip Weatherstrip | eBay
Hope that helps
David
Everything is easy when someone else is doing it
MY14 SDV6 SE Corris Grey
Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
 Master
						Subscriber
						Master
						SubscriberHi
Is this worth doing?
Tombie are you finding it necessary with the APT sliders .
I don't appear to be getting anything coming through but have not tested them properly yet
Richard
