Thread: Speedo lights not working
    Jun 2008
    Melbourne Vic
    G'day all,
    Hopefully someone can help.
    The speedo lights have stopped working in my TD5 Defender, the LHS one stopped a few weeks ago and now the other side has stopped too. I've just changed both the bulbs, presuming that they've blown, but they still don't work. The old bulbs were a little cloudy, so can't tell.
    All other dash lights are fine, the headlights are wired through a Drivesafe upgrade kit, and all work fine.
    Any ideas on what to try next?
    Is there a separate fuse for speedo lights?
    I've searched the forum and all posts I could find talk about upgrades to LED.
    I've just started a new job and work till after 6 at night, so the lights are getting a bit of workout; good thing Defenders are noisy as now I have to guess my speed for the drive home based on the noises
    Surprisingly accurate though
    Dec 2014
    Wagga Wagga
    I have no experience with the TD5 but I'd be guessing a bad earth. If you have a volt meter, check the voltage at the positive and negative side of the bulb socket with respect to a good earth (chassis) connection.
    Rob
    JDNSW's Avatar
    If it is the same as the earlier 110, the earths for the gauges, including the lights, are via a stack of tags under one of the instrument mount nuts. If this is loose, one or more of the earths is likely to be ineffective.
    Feb 2013
    Sunshine Coast
    I've never played with a TD5 speedo before, but this diagram should help. It's either going to be pin 3 or 4 of this connector. It seems to say that the earth is broken to switch the lights off - I can't imagine why they'd wire it like that given the circuit it's on but that should at least give you a starting point.
    Jun 2008
    Melbourne Vic
    Thanks for the ideas guys, and thanks very much for the circuit diagram Dervish
    I'll have to have more of a play on the weekend with a multi meter.
    I'm sure it's something simple:
