Results 1 to 10 of 15
Thread: Who has right of way? Me or you?
    Western Victoria
    And why?
    I am traveling from the left and turning right.
    You are traveling from the right and turning left.
    Back down the hill.
    The car travelling from L to R has right of way because the truncation effectively is a second T junction.
    If there was no truncation, the car coming from the right would have right of way.
    Having right of way is not a defence for failing to avoid a collision.
    Hay Point
    The car travelling from the right and turning left has right of way over the car coming from the left and turning right (you Mick). Reason - when you are turning across the traffic you must give way to anything coming from the opposite direction. Well, that's the rule in Qld anyway, but I would think it would be the same in Mexico. That is unless it is at lights then the rule changes.
    Cheers......Brian
    1985 110 V8 County
    East-South-East Girt-By-Sea
    1.20 MB
    As I understand it.
    1. In NSW I have right of way
    2. In Victoria you have right of way.
    Crafers West South Australia
    On the road pictured, the person turning left will have exited the main road before getting to your crossing point and will have to give way to you at a separate T junction as Bearman said.
    (2A) If the driver is turning left using a slip lane, the driver must give way to -
    (a) any vehicle on the road the driver is entering, or turning right at the intersection into the road the driver is entering (except a vehicle making a U-turn at the intersection); and
    (b) any other vehicle or pedestrian on the slip lane.
    AUSTRALIAN ROAD RULES - REG 69
    Back down the hill.
    Quote Originally Posted by Bearman View Post
    My belief, in Queensland, is that you have to give way to traffic whose path yo want to cross. With a truncated intersection there are two intersections, marker red and yellow in the diagram below.
    1.20 MB
    NSW doesn't use the Australian Road Rules!
    NSW Legislation
    The relevant rule in NSW is 72.
    The fact that it is a "T" intersection is irrelevant.
    Although if that is a "slip road" we can see, then IT IS Rule 69 and you have right of way.
    Sensible isn't it!
    Mar 2012
    Armstrong Creek, Qld
    Yep. Basically, after turning right, you're on the thoroughfare while the bloke on the right, turning left, has to wait to enter.
    Dec 2011
    Deerpark
    Quote Originally Posted by Mick_Marsh View Post
    And why?
    Could be wrong but person turning left gives way due to they
    have to use slip road not going from main road to main road
    Back down the hill.
    Has anyone else noticed that Mick seems to have thrown a firecracker into the room and has now bolted?
