Results 1 to 10 of 15
Thread: Stuck in Brisvegas
    Jul 2010
    Stuck in Brisvegas
    The transfer neutral problem has returned with a vengence on a trip to Brisbane. I took it up to British Offroad at Buderim to do a fault test. It came up transfer motor fault. I pulled it out hooked it up to 12 volt and it runs fine. The resistance on the potenometer moves upand down as it rotates. Put it all back together and its still giving the same warmings or saying low range etc. I did the fuse 37 thing but nothing seems to happen when i do this. Ohh and now the transfer switch wont engage at all. I will pull it all off again tomorrow and check the pins are connecting on the loom. After that im lost. Got a price on a new motor unit part 7G360 from Austral Motors $3700. So thats not going to happen is anyone making a aftermarket unit. Any ideas .... I know its a common problem but has several causes.
    Mike
    Brisbane, Queensland
    Try Duckworths in the UK. Also have a look at this pull down of a tdv8 transfer box with a brief comparison with the td6 transfer box. It might help. http://www.fullfatrr.com/forum/topic12404.html
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Queensland
    Expensive stuff there Mike.
    Where is Borumba?
    Keith
    Here is a YouTube tutorial on testing the range change motor.
    [ame]http://youtu.be/OJqd3oTsh1w[/ame]
    REMLR # 137
    Jul 2010
    Done that
    Quote Originally Posted by rar110 View Post
    yes i did this and it all works ohms cycle motor runs. I found a cheaper source in the UK Paddocks do it for ?680 around $1200 Aud. Thats a bit more reasonable. If it stops raining i will pull it off again and check the plug pins . Drove it last night for a few K's and no warnings came up. Its a poltergeist!
    Jul 2010
    Quote Originally Posted by 123rover50 View Post
    Where is Borumba?
    Keith
    Hi Keith , i drove her back to the Gold Coast and then before we set sail a young guy from Victoria bought her. He flew up paid cash and drove her home. He was moving to Nth Qld but havnt heard from him since.
    Jul 2010
    Second hand
    found a secondhand one quite cheap from that South Australian supplier. 3 months replacement warranty . $695. Its on its way.
    If it doesn't work its going back .
    Adelaide - Torrens Park
    I have come across a TD6 L322 with a poor crimp in the transfer case loom causing the vehicle to go into limp home mode (not often, but often enough). It took a long time to find it as resistance testing the loom didn't show the fault until it was wiggled in just the right way.
    Jul 2010
    All fixed
    New secondhand motor arrived fitted it in 15 mins . At first it didnt want to work steam started to comevout of my ears. I went through the fuse 37 thingy nothing ever happens when i do this. Then decided to go around the block the low range light came on sure enough i was in Low . Slowed down in Neutral flicked the switch and presto High Range. Did this a few times and the warning codes are all gone. Many thanks for all the help and special thanks to the guys at that Landrover Triumph place in South Aus. The part arrived in under 24 hrs it works and it was cheap .
    " on the road again .... Goin places that i never been ....da da da
    Jul 2010
    Spoke too soon
    spoke to soon was fixed for 10 mins as soon as i turned it off its back to failsafe program. No switching to low range. Staring to drive me nuts. Dont want to have to take it to dealer. Anyideas?
