 Fossicker
						Supporter
						Fossicker
						SupporterI've had my MY14 HSE SDV6 for 9 months now and only problem has been the above. Has only happened few times. Seems to happen when starting up a hill or going round a slow corner (e.g. when taking off at traffic lights and immediately going uphill, especially turning at the lights.)
Box sticks in D1 or D2 and is indicated as such on display. I have to put it in neutral then switch back to drive. Paddles will move the gears up and down when its in this condition . I don't think this is normal. Anyone else experience this?
14MYD4 HSE SDV6
Active Rear Diff, Snorkel, Outback Wheel Carrier, Outback Fuel Tank, OL BullBar, LLAMS, Fyrlyt, Domin8r Winch, Drifta Drawers, MSA Drop-slide, Frontrunner rack, Cargo Barrier, Codan 9323 HF, Traxide.
"The North Remembers"
After parking Boggs????
Has happened to me,worked it out on the 3rd occasion.Its possible to accidently trip a paddle whilst parking,un-parking for that matter.You dont notice until you pull out on the road and its in D2.I dont think they go as low as D1 without futher downshifts.
Possible in your case????
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Yep, if the box is in manual mode, hold the right hand paddle for about 5 seconds, and it will revert to auto.
And, as the car seems to go into manual, especially as you are turning, I would almost lay money on the paddle being bumped.
I still do it on occasion, but just grab the right hand paddle, and hold.
Link to my D4 Build Thread
D3 2005 V8 Petrol
The few times Ive done it Ive played with the paddles for a whilst after thinking geez these are fun to play with
Andrew
 Wizard
						Subscriber
						Wizard
						SubscriberAs everyone has said its probably you inadvertently touching one of the paddles when steering either hold the up paddle for a couple of seconds or just put in sport mode then back to D again and it will come out, but generally paddle is easier.
