Results 1 to 10 of 16
Thread: Stale petrol......
    Narre Warren South
    Stale petrol......
    I've had a problem with a couple of the Land Rovers that stand outside in the open. Petrol smelt 'stale' plus I had the fuel pumps stop operating, take the pump apart and it seemed the valves had stuck.
    Both vehicles would run OK but took a bit of effort to get started,
    Checked the dipstick on the military IIa fuel tank and the end was covered in sludge and the brass was being eroded. The fuel had gone off and was leaving a lovely brown sludge everywhere.
    Dropped the tank and took the picture below through the level sensor opening.
    Looks like it needs a bit of work to de-rust and clean the inside before sealing it to stop further rusting.
    Rigged up a temporary tank, dropped the sedimenter bowl and cleaned it then flushed the fuel system through. Starts & runs a lot better on fresh fuel, funny that......
    Temporary tank will stay for a while while.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Quote Originally Posted by gromit View Post
    I derusted a tank with molasses and water solution.
    Narre Warren South
    A lot of the brown stuff at the bottom isn't rust, I have to find something to dissolve that first.
    With molasses I read somewhere that having something half in caused problems with rusting at the barrier between the molasses & the air. Did you brim the tank with molasses ?
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    MoveLater2
    Yes, I did write about the interface problem and I did fill my tank to the brim.
    I haven't tried tank sealers but a few blokes have used them for their motorbike tanks which seem to be very vulnerable to rust.
    Oct 2007
    Wantabadgery, N.S.W.
    These days the petrol needs a fuel stabiliser if being left for any extended period. The stuff is not expensive.
    Don
    Narre Warren South
    Quote Originally Posted by Don 130 View Post
    Don
    I understand it only stabilises for up to a year.
    Probably better if your not yet using the vehicle to either drain completely or keep the fuel level low and drain it out annually and replace with fresh.
    I added fresh to the old fuel (no idea how long it had been in there).
    Once the tank is cleaned up & coated I might stay with the temporary tank until I get the vehicle back on the road.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    The extent of the stale fuel problem is largely a function of the humidity. Not much of a problem inland, and the more humid the worse it gets. Mainly due to bacterial action at the interface between the fuel and water that condenses with changes of temperature (The bigger the daily change in temperature and the higher the humidity, the more condensation you get.)
    The solution is to either drain the fuel completely from the tank (and drain condensation before putting it back into service) or alternatively fill the tank completely before the vehicle is stored, which will largely prevent condensation. And if possible avoid using fuel with ethanol in it, as this makes the water miscible with condensed water, so that bacterial action can take place anyway. A fuel stabiliser will help, but how long it lasts will depend on how much condensation exists, so use it in addition to the above precautions.
    the best thing you can do is use the fuel.
    fit a facet pump and an openable stop cock to the fuel line. when you need to do the lawns open the cock, fit a hose and turn on the pump then fill the mower.
    when you're done (one a month or si go for a drive in the vehicle as a "maintenance run" and top the tank off.
    more fuel with less ullage space lasts longer than a partially filled tank.
    Narre Warren South
    Can't afford to have loads of Land Rovers sitting around with full fuel tanks so I think I might drop the contents, leave the tank vented and switch to a temporary tank when I want to move it around the property.
    Once it gets back on the road I can re-connect the tank.
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    May 2015
    Southern Adelaide
    You'll find that 95 octane fuel lasts better than 91 but yeah, stale fuel is still an issue.
