This may give you an idea Will, the 57sec mark of the vid
Baz.
Hi all, does anyone know what the centre recovery points at the front and rear of a D3/4 are rated to? Is there an actual rating from LR for these 2 points?
Regards, Will
LLAMS, FYRLYTS, OL D4 Bar
Baz.
Cheers Baz.
2011 Discovery 4 SE 2.7L
2007 BMW R1200GS
1979 BMW R80/7
1994 Yamaha XT225 Serow
Geez some people are brutal to equipment they don't own or care about.
I'm particularly interested in knowing the load limits and strengths. As an example I might wish to recover a truck that's spinning wheels in mud but is not bogged to the axles. I'd use a couple of 4.75t rated shackles and a 12t tow strap, with no shock load. Using a tight strap gentle pull, am I likely to break the loop off the back of the chassis?
I realise that there are a lot of variables to the question. I suppose I'm just asking how strong the loops are for low stretch applications such as a tow strap or a chain, used sensibly without shock.
Regards, Will
And that would be SWL ( safe working load) and not failure load.
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
As I understand it, failure load is normally 5 to 7 times the SWL. So realistically pretty much anything could be recovered provided it's not too badly bogged. Sounds to me like you'd have trouble with traction before you broke the rear loop, provided there was straight pull load without any shock.
Regards, Will
This might give you an idea of the static load.
[ame]https://www.youtube.com/watch?v=c3LIWXCuUUc[/ame]
I pulled a tree stump out with mine.
Sean
