Hi All,
I'm in the process of rebuilding my SIII Suffix "D" box and correcting the alignment of the adapter plate on the HJ 202 Red block.
Can anyone tell me where to get a quality spigot bush to suit the Holden crank and SIII primary shaft?
Also, have you any suggestions for any other modifications I should consider while the gearbox is apart? The transfer case has a high-speed high range conversion.
Thanks,
Ian &
Leo - SIII 109/GMH3.3
Daphne I - '97 Disco 300Tdi Manual
Daphne II - '03 Disco Td5 Auto
4 Wheel drives used to carry them. Their part number is a C18B but they were listed in an old catalogue at $22 whereas a STD Land Rover one was $4.40. Phone them, don't rely on the website.
Four Wheel Drives Pty Ltd, Largest Range of 4x4 Parts and Accessories in Australia.
Otherwise measure OD, ID & depth and go to a bearing stockist.....
Colin
'65 Series IIa Dormobile
'70 SIIa GS
'76 SIII 88" (Isuzu C240)
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
There are bushes available for the conversion and although they do the job there are better options. (listed as C18B $20 each. in Four Wheel Drives catalogue.)
With the Holden conversion the spigot shaft only just reaches the (standard length) bush, so only about 1/3 of the shaft runs in it. If you have access to a lathe these are the options. One option is to knock up a longer bush out of sintered bronze. The other is to make a steel bush that is a press fit into the centre of the Holden flywheel that will then take a standard Land Rover spigot bush (1.125" x .875").
Hope this helps.
Cheers, Mick.
1974 S3 88 Holden 186.
1971 S2A 88
1972 S3 88 x 2
1959 S2 88 ARN 111-014
1959 S2 88 ARN 111-556
REMLR 88
1969 BSA Bantam B175
'70 SIIa GS
'81 SIII FFR
'95 Defender Tanami
Motorcycles :-
Further to my previous post.
Here is a pic!
Cheers, Mick.
1971 S2A 88
1972 S3 88 x 2
REMLR 88
Hi Guys,
Thanks for all the suggestions. I'm learning more about bushes but would appreciate some clarification.
I believe sintered bronze bushes should be soaked in oil before fitting and then not need any other lubrication, yes? What about plain solid bronze bushes? Is it good practice to put these together with a little molybdenum disulphide grease inside the bush? Or are there better options - dry lubes etc??
Thanks again.
Ian &
