 Originally Posted by
digger
Cheers Kyle,
there is nothing in or apparently wrong with existing wiring etc to rear plug or in fact any wiring Ive seen. I havent had a feel for the reverse switch and am not sure what it looks like or where exactly it is plugged so I may climb under for a search about for that. But I assume the reverse light comes on when a connection is made by gearstick selector?? so Id have thought if it was loose or came off it would not work as opposed to not stop working...
Im assuming the light gets that hot it takes the fuse out!?
thanks again kyle, any suggestions  are really appreciated!
have you heard anything about that lift?
