Thread: 2003 L322 Vogue
    Rob1986 Guest
    2003 L322 Vogue
    Hi all,
    Just wanted to introduce myself, i'm Rob and i have just bought a 2003 l322 4.4 Vogue in Grey, K's are high but they are mainly country K's and I think I got it at a good price (260000km -$14,000). Previous owner has it serviced at an approved Land Rover garage over in Perth and i have copies of all invoices/work carried out there. I had to have it shipped from Perth to Adelaide and it's currently sat at a train station in Adelaide as i can't pick it up until it gets to the transport companies depo
    Below is all work carried out in the last couple of years (minus scheduled services etc) is there anything else that people can think of that I should inspect once it arrives?
    SERVICE HISTORY
    198237km
    ? Water pump replacement, new drive and AC belts
    ? Trans service
    202224km
    ? Replace fuel pump
    ? Fit new side steps (along with mudguard adjustment kit apparently)
    ? Replace relay and replace failed compressor
    214679km
    ? Coolant leak (remove and install new expansion tank)
    222733km
    ? Replace rear pads and disks
    ? Renew both front and rear control arms
    ? Renew lower ball joints for lower arms
    ? 4 x new tyres
    ? New LHR light
    229479km
    ? Replace/renew ignition switch
    232964km
    ? Replace/renew Oil sump and gasket
    254613km
    ? Replace coil packs x4 (1,3,5,7)
    ? 8 x spark plugs
    241363km
    ? Replace radiator and thermostat
    242073km
    ? 2 failed coil packs, all got replaced (some under warranty)
    251746km
    ? Replace breather hose, breather gasket, manifold gasket and vacuum lines x 3
    ? Renew valley pan, tubes and water pump gasket and PCB valve
    255116km
    ? Replace transmission (new gearbox)
    ? Fit new oil cooler
    ? Fit torque convertor
    ? Fit new air flow meter
    257969km
    ? Coolant hose split and was replaced (unsure which one)
    258699km
    Holding Gear? (issue with throttle body and no the new gearbox)
    ? Fit new throttle body
    ? Install new battery
    260000km Mine
    Nov 2005
    Maudsland, QLD
    They are an awesome vehicle. You will love it!
    2023 Defender 130 D300
    SOLD - 2010 Discovery 4 V8
    SOLD - 2008 Range Rover Vogue L322 TDV8
    SOLD - 2006 Range Rover Sport L320 TDV6
    SOLD - 2002 Range Rover L322 TD6
    SOLD - 2002 Discovery 2 TD5
    SOLD - 1997 Range Rover 4.6 HSE
    SOLD - 1999 Range Rover 4.0 SE
    Brisbane, Queensland
    $14000, incl new tranny, is good buying IMHO.
    PICS PLEASE.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Manly QLD
    yeah, that's a lot of car for 14k
    Dec 2011
    Forrestfield WA
    You can see why the previous owner got sick of paying for repairs but he seems to have sold it after fixing nearly everything, which seems a bit stupid unless there is something major that you don't know about. I would get the coolant checked for hydro carbons in case the head gaskets have gone, with possibly a couple of overheating episodes in the mix, looking at some of the repairs.
    Bob
    Avoca Beach
    No mention of timing chain guides which are a known problem so maybe worthwhile having replaced or at least inspected.
    There is a recent thread on this.
    Great that the transmission was replaced.
    Looks to be a good buy.
    Regards Philip A
    Rob1986 Guest
    Smile
    Quote Originally Posted by BobD View Post
    Had the RAA inspect it (INC pressure tests) I think they check for exhaust gasses in the coolant too so hopefully I should be OK. Previous owner is loaded and has just bought a 2014 TDV8 so he had a genuine reason for sale.
    Dec 2008
    Victoria
    That seems like a great buy for the money. At 260K on the clock I would expect a few things to have got tired and need replacing. The previous owner seems to have kept on top of the maintenance hence keeping the car reliable.
    Welcome to the forum too Rob. It needs more Rangie drivers in order to keep those pesky Defender drivers at bay.
    Rob1986 Guest
    Quote Originally Posted by rar110 View Post
    PICS PLEASE.
    Not the greatest pics as the previous owner is in his late 70's but i will get more once I have it...
    photoupload
    Rob1986 Guest
    Collected It :)
    OK so i've just driven it back from Adelaide (5 Hrs to Mount Gambier) and it's amazing, never missed a beat and so comfortable!! Trip computer must be wrong i think though as it claims 11.9l/100km and i have 374k's left til empty. It was mainly cruising at 110 and it used just over half a tank so i'm stoked either way. One thing I did notice is that i cant get the radio working - the time and date was a few days out too so not sure if it's something to do with the battery (previous owner said it was working before it was put on the train) Any ideas??
