I'd be triple checking the oil used for that price
 Wizard
						Supporter
						Wizard
						Supporterhi all,
thought i would pass on a great deal i got for updating my plastic auto trans pan for a steel one, new gasket, new oil, serviced at a mob never used before and with no connection to them in west ryde named Advanced Auto Trans.
before i tell you how much i did some research and found LR outlets selling the steel pan conversion for $400 alone, then the $$$ for the oil, not sure of the price of the filter though. people have been quoting close to $1000 for the service. i only called one local supplier and was told the price for it, a grand total of $385 incl of steel pan, gasket, oil, filter & GST, total.
i had to ask twice for the price in case i heard incorrectly. you cant beat that price can you. was told the correct oil was used for that trans, friendly service, very happy customer. look them up if yours need doing. cheers
Amazing price! Did that include the full mega flush and were you told the brand of ATF?
Sean
Did they replace the sump eith a steel one? I see the plastic one advertised as a replacement unit recently.
Either way thats a great price considering the price of the lifegard 6 oil thats used or should be used.
Cheers Ean
 Master
						Supporter
						Master
						SupporterSounds like the urban myth of 'no free lunch' is a hoax.
I thought the price of the oil alone was double that?
Could it be a different oil used .. and will it cope? Oils aint oils they say!
Great work - if all above the decks.
D3 2005 4.4 V8 HSE java Black.Alpine Roof,Alpaca Leather 7seat,LRSat Nav,E diff,Bi Xenon.Hi-Ice et.voice control.Bluetooth Phone.Kaymar rearbar.Roofrails and Racks.18rims.Traxide Dual Battery towpoint Anderson plug. Xenon 4300k Hbeam.10wled450lightbar.
I have trouble believing that they used the right amount of the right transmission fluid plus steel pan, filter and labour for that price. Something fishy.
But if truly all above board that is an amazing deal.
I think I would check for details when the tranny takes approximately 9 lts of Lifeguard6 at approx $30 per litre plus cost of filter, steel pan etc.
It's great to save money, I'm all for it. But not if will cost a $6000 tranny rebuild because the wrong tranny fluid etc. If it checks out, great.
L322 tdv8 poverty pack - wow
Track Trailer ARN 200-117
REMLR # 137
 Master
						Master
						Just fitted a BMW (with drain plug) steel pan and done 2nd 5ltr auto trans drain / fill.
Total cost: $350.00 for steel pan and genuine gasket from Furious Performance.
$160.00 5Ltrs Lifeguard 6 from Repco @ $645.00 for 20ltr drum.
$15.00 for gasket sealant.
Total: $525.00 and about 4 hours labour (mine) - I work slowly.
Plenty of "Liquid Gold" left for two more drain / fill cycles.
2005 D3 TDV6 HSE @ 244K
-Wasa
Hi Wasa,
Four hours sounds quite reasonable, we must work at the same pace. My prices and time more or less mirrors yours. I got my steel pan kit of Ebay, roughly the same price with the drain plug. I also took the old magnets out of the old sump and put them in the new steel sump. More magnets the better.............or so I have been led to believe.
 Master
						Master
						Much crud on the magnets after removal, Nomad? I didn't see any magnets in the plastic pan I removed (not surprising after attacking it with an angle grinder!)
I was thinking of adding magnets (perhaps in sheet-form) to the outside / under the steel pan. Being metal, I can't forsee a problem. Thoughts anyone?
-Wasa
