Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: Head-on collision
    Sep 2013
    melbourne
    Head-on collision
    Making my way home last night travelling on 60km/h through an intersection, a driver in an astra quickly pulled out to turn in front of me. So i swerved away, gave him my driver side corner, and locked up. Too late to avoid him as he plowed into me. Spun him right around.
    We both walked from the cars, just a little shaken.
    Here are the results...
    Broken steering arm snapped and punctured the fuel tank, powr steering leaking and its bent other arms underneath, front wheels pointing different directions and wheel is pushed back, one side of the bull bar has been sheered clean off at the bottom. Front corners crumpled.
    Intercooler and turbo piping, headlight all looked intact.
    Here are some pics.uploadfromtaptalk1438327703376.jpguploadfromtaptalk1438327809462.jpg
    2011 D4 SDV6, Rhino rack, UHF radio, Airflow snorkel, Tuff Ant's 265/65/18 Kumho KL61, 3 Way Lift Rods, Traxide dual battery, Korr LED light bar, APT gear: Rock sliders - Air Comp Guard - Air tank guard - Engine/sump guard - Front guard - Tranny guard
    LandroverScott Guest
    thanks for sharing, glad you're OK.
    chassis OK?
    other car much worse off
    Sep 2013
    melbourne
    Cheers mate
    Not sure how straight chasis is after it, the body shop told me theyd let me know how bad things are on monday
    Bearman's Avatar
    Hay Point
    Hopefully no serious damage to the perentie, but if the wheel has been pushed back it has probably damaged the chassis where the front radius rod pivots. Looks like the astra came off second best (if that's any consolation) You need a proper bull bar instead of that coat hanger!
    Cheers......Brian
    1985 110 V8 County
    East-South-East Girt-By-Sea
    1.20 MB
    You need to get underneath and rub your hands down both sides of the chassis for rippling in the side walls and underneath for kinking. Especially check where the radius arm bracket is attached to the chassis (next to fuel tank) and where the spring mount bracket is on the chassis.
    This will be the determining factor whether the vehicle is repairable or a statutory write off. (Not allowed to use chassis straightening anymore).
    Jul 2013
    Good luck mate - hopefully all straight I know you've put a whole bunch or work into that beast.
    Mar 2015
    dang. That's some bad luck.
    Hope you were insured. If you were and they write it off, see how much they want to buy it back off the insurance company.
    You may be able to make some money parting it out. Lots of panels, engine transfer case and gearbox, not too mention the winch that should still be sellable for a decent amount.
    Sep 2013
    melbourne
    The panel beater was telling me to look for a new bull bar so he could include it in his quote. Anyone know which bull bar is out there to suit the perentie with pto winch?
    We both have insurance, I'm insured agreed for $20k through Shannons. So far only dealing through his insurance, we'll see how it goes.
    Organised a rental which his insurance will pay for, through acorn replacement vehicles, they take care of it all.
    ....just hoping its not written off...
    Jul 2013
    I have one if you need it, has a small dent it one of the cross struts but otherwise all ok. It's the same style as yours. Are you Sydney based? PM me if you're interested. The panel beater may be able to fix the minor dent.
    Edit: sorry I see you would need a new bar here : Maybe rijidij ?I thought he was looking at making them
    Jan 2010
    On sebaticle with work in Penang for a bit life is good 👍
    Try APT
