24th June 2005, 10:02 PM
Fading Lights
Hi All
For a while now the headlights on my disco noticably dim when I brake, indicate, the aircon comes on etc. Obviously the extra power drain by whatever accessory kicking in is causing this. It is running an Optima calcium battery of unknown age and I'm wondering if this is past its useby date or does it indicate a potential fault with the alternator?:roll:
Any suggestions on what to check/change?
Cameron
24th June 2005, 11:53 PM
Try using a voltimeter to check the condition of the battery it should be betweeen 12-13volts reading
25th June 2005, 01:19 PM
Sounds like a weak battery earth. Try cleaning the earth connections to the body and motor.
For peace of mind you can get the battery electronically load tested at auto shops however usual load test is starting the motor. If it winds the motor easily there can't be much wrong with it.
