Results 1 to 10 of 25
Thread: Rear drawer/fridge slide systems for L322?
    Sep 2010
    Dunsborough
    Hello chaps and chapettes, do any of you wise people have any knowledge of fridge slide/drawer systems for the L322?
    I'm a bit over just chucking stuff in the back and discovering the one thing I really want is right at the bottom of the pile. And I can't open the Engel without dragging it out onto the tailgate first.
    I've looked around online but can't find much that's particularly helpful.
    Feb 2014
    Either make your own or use a universal...however...and a big however.
    If you put a draw system in, especially with a fridge, you will not be able to access your spare tyre (without considerable efforts to remove on the side of the road, possibly alone)
    My best suggestion, and something I am working on atm is making smaller, individual draw sets that are not bolted down, for easy removal. (Even tho my spare tyre is on the back, i still want to access water tanks/compressors in the event of a failure)
    the fridge slides require them to be secured to a solid frame that can offset the weight of the fridge, again, not possible if you want to get to your tyre. best thing to do, is make sure it can slide easily on the carpet or mat.
    Edit: if it is also to close to the edges of the boot space, you will not be able to access fuse panels etc
    Sep 2010
    Dunsborough
    Mmmm, I guess I figured there'd be no easy solution. I might look at designing a simple upside-down U-shaped arrangement in carpet-covered marine ply that would at least be light enough to haul out in an emergency, and I'll just put up with having to drag the fridge out, without having a bolt-down slide.
    Feb 2014
    What I did prior to having my fridge was a false floor setup with a steel frame (an early, unfinished photo of it attached) where the legs would come down near the restraint mountings in the floor, this allowed the bottom to be accessed after removing all the tubs etc from under it. The outer panels of wood were on hinges to fold up and allow access to the side panels.
    Something like this would just be to high for a fridge to sit on and probably not structurally viable if you have to cut a hole in it to slide a fridge in and out, so i ended up scrapping it.
    Sep 2010
    Dunsborough
    Thanks for that. I'm thinking of something that sits about the height of the existing factory sliding screen, which the fridge would fit under, along with a couple of drawers to one side.
    I'll see what I or my shipwright mate can come up with in marine ply.
    NSW SW Slopes
    In my D4 I access the fridge over the closed bottom tailgate lifting the lid towards the side window and had hoped to do the same on the L322. I'll discover any shortcomings in that idea after I get the car home Monday and start the change-over process.
    Sep 2010
    Dunsborough
    Unfortunately with the slope of the rear window on the L322 the fridge has to go inboard a fair bit so it's a bit of a lean in Graeme.
    Aug 2013
    Howrah, Tas
    Hi.
    I have made my fridge slide with the use of aluminum square tubing then cover in non construction ply. And then made same with two draws for food and recovery gear. These two pictures are my food storage. Don't fridge draw picture om phone. It's easy for me to remove to access the spare tyre.
    Jason
    Sent from my GT-I9505 using AULRO mobile app
    Jason
    Range rover l322 2002 TD6
    Queensland
    Fridge slide
    Greg, I had Drifta make me a false floor same size as spare wheel well cover and it bolts in using existing tie down points. The separate fridge box and slide is bolted to the floor. Works a treat
    L405, Vogue SE, 4.4SDV8, 8 speed, Rear e-diff
    Sep 2010
    Dunsborough
    Now that looks the business Chris. Where are they? Can they make a replica?
