Results 1 to 10 of 13
Thread: Bogged the Mog..
    Oct 2011
    Burra NSW
    Bogged the Mog..
    Bogged the unboggable!
    Jul 2009
    Hobart
    Hi,
    Take 9 boy scouts ....... no, that was a bogged kombi.
    Waiting for the rest of the tale.
    its not bogbbbged yet, I can still see the tray and the door handles.
    if its got its full CES and is FF that thing is coming out under its own power.
    Apr 2012
    Orange, NSW
    I agree with Dave, that's not bogged.
    Hell, we bogged ours FAR worse than that and we were only a bunch of cadets.
    When a mog is sitting on it's chassis, THAT'S bogged.
    Of course, I got to watch the Army try and snatch it out with 3 perenties chained together. That wasn't pretty....
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
    Oct 2011
    Burra NSW
    Ha, thanks dave, true the tray isn't under..but the back diff and tow bar are on the deck as well as the crane leg.. I have no idea what the hell CES and FF IS, some sort of military talk no doubt..I've recovered a fair bit of bogged equipment, and Trust me it's bogged and in no way was coming out under its own power, sure, if I was on my own and stranded I would have got it out given plenty of time.. our 140 grader wouldn't pull it out and ended up bogged itself, different country down here when it gets wet, to what you've got up here.. Volvo digger pulled both out with some effort.. One thing I've found with the Mog is that these tyres are near useless off road, they are crap on wet grass, rubbish in mud, and terrible for floatation even when aired down..good in the rocks and shale though..
    May 2003
    On The Road
    I would've thought a grader was impossible to bog,,
    Where's Andy when you need him?
    Quote Originally Posted by Summiitt View Post
    yeah the double coils are crap.
    CES = Complete Equipmetn Schedule
    FF= Fully Functional
    If the crane was working it was coming out under its onwn power, I never said it was going to drive out...
    if you havent sunk the outriggers you use the jacking pads to disperse the weight and if you need to you double stack them on one side and then use the spare tyre under them. jack up one side and fill the ground, repeat on the other side.
    If you need more lift set the apre down pad it fold the crane over so the tele is verticle then extend. if you overload that hydraulic circuit you can short slide the tele and use the shoulder joint to push down. be careful though as it will walk the head of the tele on the pads.
    you can also ue the slew to get some forwards push as someone eases it out in first but thats really really dodgy.
    If your on the axles and you cant lift it with the hydraulics...
    chock the chassis at the back as far outboard as you can, strop the wheels use the crane to compress the suspension and then fill in the ground back of the crane an the suspension will lift the chassis, alternate side to sie and keep going till you can get the jack under the chassis jack up and keep wheel filling.
    it takes 4 people 8 hours to get a fully loaded stores mog out of about that badly bogged but it beats just waiting for the 2 days for the recovery crew to come out.
    CES is the complete
    Oct 2011
    Burra NSW
    Pedro, graders are surprisingly easy to bog, massive amount of weight on the tandems, and a belly plate that runs from the front of the rippers to the front of the cab, you've only got to just above the 'diff centres' before they will belly out, then the belly plate acts like a giant suction cap and your in the crap..
    Thanks dave, considered using the outriggers, but never thought of the spare tyre as a block..great idea, I suppose the army had some pretty 'do anything to get out of a bog training ideas..
    Adelaide Hills - SA
    And it looks so innocuous!
    Will you be looking at new tyres after that?
    Oct 2011
    Burra NSW
    Would love to, but the things got to earn its keep, plus the tyres were brand new so only have 12k on them.. Will keep an eye out for something with a wider footprint down the track..but from experience, once you break thru the top 4 inches, tyres mean very little..it's all about floatation!
