Results 1 to 10 of 23
Thread: Flappy whiring sound, maybe transfer box?
    Feb 2012
    Parkdale, Melbourne
    OK, my Disco (manual TDI) has started making a funny noise. I fear it's bad news...
    I don't know how to describe noises... It kind of reminds me of putting a flap in a bike spokes. Not as high pitched though. I considered exhaust leak, but can't see any obvious black marks and I would describe it as a bit more metallic than the soft sound of air.
    Frequency matches gearbox speed. If I let the clutch out at 60km/h in 3rd, then the same in 2nd, it is higher frequency in 2nd.
    While driving, if I put my foot on the clutch it goes away.
    Starts again as the clutch takes up.
    Can't get it to do it by revving the engine stopped.
    Can't get it to do it with transfer box in neutral and revving the engine in gear.
    Sound exists in high range, diff lock and low range.
    Lastly, I got up some speed, slipped the transfer box into neutral, let the clutch out in gear and I can't get it to make the sound.... Thus I'm thinking transfer box related.
    Thoughts?
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
    Feb 2012
    Parkdale, Melbourne
    Bump....
    Maybe I should have chosen a better title!
    - Justin
    May 2014
    Point Cook, VIC
    I would suspect gearbox lay shaft bearing as you said frequency increases if you change from 3rd to 2nd (I assume at same road speed, hence higher rpm). Is it more noticeable in 2nd and 3rd, but much quieter in 4th?
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    I had a throw out bearing go once on the clutch and it made strange noises.
    South Yundreup,WA.
    It depends. I have had similar in a Disco, RRC and Defender all R380/LT230 setups. Mine would only do it around 80kmph. I reckon it might be one of the wring harnesses getting a bit of movement and hitting against the box or body. Only did it around 80kmph and in 4th or 5th. Never did actually track down what it was.
    Does it do it all the time in all gears or just intermittently?
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Feb 2012
    Parkdale, Melbourne
    Just went for a short drive and I think it's bad news.
    Quite distinct in 1st, 2nd and 3rd. 4th is no sound or so quiet I can't hear it. Didn't get fast enough to try 5th much above idle revs, but I reckon I could just hear it.
    I'm sure it's there all the time in at least 1st 2nd and 3rd - it's just hard to hear over the engine with revs up. Let the revs drop while changing gears, then let the clutch take up and it very distinctly starts as the clutch grabs.
    Anything else I can do to confirm it's layshaft bearings?
    I was reading some other threads on it, and sounds like the layshaft bearings can be changed without removing the gearbox. Remove transfer box, then just unbolt extension housing from gearbox. Sounds good to me? It's done 175,000 kms. Oil has always been clean and full between service intervals and still feels great to drive.
    - Justin
    South Yundreup,WA.
    Sorry just re read your whole post. It does sound a little like a failure of some sort.
    It may be possible to replace the rear bearing in situ, but I would take it out and either fit a recon unit or do a full rebuild. If it is the front bearing you will need to pull it out.
    A flapping noise is unusual, normally bearings would be more of a squeal or groan.
    When mine failed it was the front bearing that failed or I should say the retainer broke and the ball bearing fell out and presto no drive.
    Have you dropped the oil to see if there are any filings in it?
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Feb 2012
    Parkdale, Melbourne
    No filing in the oil, but golden specks sitting in the bottom. I assume this is brass from the syncros and nothing serious....
    I'm definitely considering another box and just swapping it. I was hoping this wasn't going to cost too much, but I think I'm out of luck if it's the gearbox!
    - Justin
    South Yundreup,WA.
    Judo,
    The brass filings are fairly normal. When mine went I ordered a box from Ashcrofts in the UK. From time of ordering including build with HD bearings was around 3 weeks, 2 weeks to build and 1 week delivery, may have actually been a bit quicker than that. If you are fairly certain it is on the way out would be the way to go. Even with paying the core charge and freight was a lot cheaper than getting a standard rebuilt R380 here. Ring or email Dave direct if you go down this path. Of course let him know we have recommended them. Very easy to deal with.
    A lot will depend on your time frame if you can have it off the road for a month then I would start by removing the box and inspecting first. You may also be able to get an endoscope in through fill and drain points to have a look first. Once you have determined if the box does need a rebuild determine if you want to rebuild or just get another box. The benefit of getting the Ashcroft box is you get to keep the old one and rebuild at your leisure as a spare or for other projects. You can send yours to Ashcrofts for core exchange but you will only be about $100 or less better off as freight is around $200 one way if you actually get the same rate, then packing as well.
    If you can do the swap yourself it will make it economical. If not will add some serious coin in labour.
    Are you sure it is not a clutch failing? I would also do the clutch and spiggot while out, around $700 from Karcraft for clutch and new flywheel.
    Craig
    Quote Originally Posted by Judo View Post
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Feb 2012
    Parkdale, Melbourne
    Craig,
    Thinking of trying some exploratory work this weekend. Maybe remove transfer box and take a look at that first. Famous last words, but it seems like I could remove and refit the transfer box without spending weeks on it. If that looks good, it's either gearbox or clutch.
    Not being able to hear anything in 4th, but gears 1-3 being noisy make me think I have enough evidence to buy a new/recon R380 and just go the swap. Really the worst case is that it's something else and I still have a second good condition box I could on-sell again.
    If I'm removing the gearbox, yes I would definitely do the clutch too. I see karcraft do a clutch kit for $300. Is that everything I need? I think that includes cover plate, friction plate and clutch release bearing? It's a 300TDI - do I need to replace the flywheel? (I hear that's a yes on TD5, not sure about TDI).
    Unfortunately the Disco is our only car! We don't drive much though (train to work), so I can spend a few weekends on it, but months off the road becomes a long time... The problem I have every time I do major work is that I can't duck around the corner for that $2 part I need! But there are ways and I make do... I justify it to myself as even if I get a taxi to bunnings a few times a year, that will always be cheaper than owning a second car! Picking up a gearbox in a taxi might be a different story tho.
    Cheers.
    - Justin
