Results 1 to 9 of 9
Thread: Painting blue steel
    Sep 2006
    Northern Beaches
    Painting blue steel
    I have made a bead breaker and bike lifter from steel with a blue coating. I want to paint them, but should I remove the blue or just paint over it?
    Jeff
    Torres Straits
    The blue is a primer.
    Degrease and clean welds then paint away.
    S
    As roverrescue says. I would be inclined to put a coat of primer on the welds.
    Jul 2008
    Everything they say.
    It's important when coating grind away sharp edges then stripe coat them with a primer before applying the all over primer.
    The paint withdraws from the edges leaving it very thin.
    Corrosion very often start at the welds too due to changes in metal composition.
    Clive
    Sep 2006
    Northern Beaches
    Thanks for the replies everybody. I had a nice sunny day this morning, so got into it. I put the bits in the sun so they would not be too cold and wiped them with prepsol, then started spraying with black Killrust paint. Killrust says it doesn't need primer, so will do an extra coat over the welded bits.
    Well I sprayed the upright and the lever and the spray can ran out of puff. There was plenty of paint in the can, but no propellant So I grabbed a tin of normal Killrust and a brush to finish it off and you guessed it, it went over cold and started to spit rain The bits are hanging on wires in the garage for now and I'll check on them tomorrow.
    Jeff
    Mar 2011
    South Aust
    Sit the spray can in some warm (not hot) water to give it some pressure.
    I always preheat my spray cans before spraying. Turns out much better than cold can/paint.
    Irymple, Victoria, Australia
    Quote Originally Posted by SouthOz View Post
    Crushing the can a bit always works when you need to wring that last bit out when there is paint remaining but they have lost their pressure!
    Cheers, Mick.
    1974 S3 88 Holden 186.
    1971 S2A 88
    1972 S3 88 x 2
    1959 S2 88 ARN 111-014
    1959 S2 88 ARN 111-556
    REMLR 88
    1969 BSA Bantam B175
    Crafers West South Australia
    Quote Originally Posted by mick88 View Post
    Cheers, Mick.
    So does a shot of compressed air from a dust gun, just remove the spray head and inflate.
    Sep 2006
    Northern Beaches
    I painted the bead breaker and lifter, and the paint is quite fragile and peels off easily. Is that a problem with Killrust, or should I have used a proper primer?
    Jeff
